Question about IBM ThinkVision L170 17" LCD Monitor
Can't adjust the color, brightness or contrast so that there is a pure white color. Can this be fixed?
    Top Expert:
  • 12,223 Answers
Yes you can. Go to Menu, and follow the steps for adjust the color, brightness ,etc or restore the factory default in Menu
God bless you
Posted on Jul 31, 2013
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Colors are off on the TV. When I try to adjust the contrast and brightness, etc from the menu, either everything is orange or green or yellow.
Contrast and brightness won't fix it.You are on the right path though.You need to search around for a color adjustment.You should have numbered scales for all 3 primary colors to adjust.It should also be somewhere under the picture option.Let me know if you need better instructions.Good luck!
Aug 05, 2010 | Toshiba 42AV500U 42 in. LCD HDTV
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
No contrast
first turn your color all way off or down.try turning your contrast way down as far as it will go you should see a darker picture. now bring up the brightness to a point half way. bring the contrast up to see grays and whites and blacks...adjust brightness more if need be. now you should see a nice black and white picture. no bring your color up last ...not saturate but to your liking. if you stilll got problems i bet your video out transistor is shorted....meaning shop work.
Aug 31, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Color Problem after replaced Circut Board
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
Jul 23, 2007 | Zenith SY3572DT TV
Monitor Screen Bright with horizontal white lines
I have an emachine 17" Flat Panel Monitor and I accidently touched the Standby Mode on my keyboard and now my menu won't work right. I can't adjust the color enough. If there is anything I can do to fix my problem it would be appreciated.
Thanks
Oct 08, 2006 | E-Machines 17F2 17" CRT Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
