Question about Maestro Electrical Supplies
Lutron Maestro Multo Location Dimmers... I have power to all of the screws in both dimmers except for the black screw where the switch leg (lights) is connected. Help, can't figure it out
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
We always need more information but here is some general info.. Use it if it fits. 3 screws on a 3 way switch. Gold color is for power line. Silver color is for light fixture and black screws are tied together between the switches. (called the traveler) Hope this helps.
Posted on Dec 13, 2013
  • 5 Answers
SOURCE: I went to replace the Lutron Skylark dimmer with
The 2 wires that are tied to each other is most likey your hot lead from the panel , the other goes to the light.Tie 1 blk dimmer wire to the 2 wires together and the other blk dimmer wire to the single in the back.Also Maestro dimmers have a small kill switch check to see that it is not off.If you work with hot leads remember don't cross your heart ( wires in both hands current passes through the body)
Posted on Sep 02, 2009
  • 323 Answers
SOURCE: Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Posted on Oct 31, 2009
SOURCE: 4 can lights wired to two 3 wire Lutron
The interior flood light bulbs were the new flourescent energy savers. I replaced them with incandescent and it worked with the dimmers.
Posted on Dec 17, 2009
al_kupchella
  • 843 Answers
SOURCE: connecting 2 dimmers one one wall mount
The dimmer with 4 wires is a 4-way switch, but to use it as a single switch you only need two of the wires. Use one from the top and one from the bottom. Cap off the other two wires on this switch (independently, not together). . From among the 4 wires coming from the wall you need to find the one incoming hot wire, and identify what each of the other 3 wires feeds. Temporarily cap off one of those 4 wires and connect the other three together. Turn on the breaker. If nothing lights up, the single wire is the hot wire. If two things light up, the single wire is the thing that didn't light up. Label your findings so far. Turn off power, then try other combinations until you have identified all 4 of these wires. . Your single hot wire needs to connect to one terminal on all three switches. The other 3 wires will each be connected to the remaining terminal on one of the switches. . I don't know what style your 4 way switch is, but if you find that it operates "up-side-down" (up being off and down being on), then you can remedy that. If your outgoing terminal on that switch was say, the lower left, then swap it with the lower right. . Good luck. Thanks for using FixYa! Al Kupchella
Posted on Apr 15, 2010
SOURCE: Lutron dimmers throught the house,
I have spent considerable time on the Lutron site past couple days looking at their dimmers.
Lutron has a lot of dimmer varieties. The basic breakdown is 600Watt and 1000Watt. But different dimmers control different types of lighting.
Here is the long list of Lutron dimmer manuals:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
Posted on Oct 18, 2010
Where does neutral wire go at end of circuit?
If there is only a white and black and ground coming into the box from the fixture then that white is probably really a black. The black is hot, meaning it has power. The white takes the power back to the light. If you can open the light fixture box and see what wires power the light.
Jan 11, 2016 | Lutron Maestro 150-Watt Multi-Location...
Can I reuse a Lutron Maestro MAW-603 dimmer in a 2 way situation?
you should be able to by hooking up the black wire on the dimmer to the hot wire(that comes from the electrical panel) in the wall box and the red wire from dimmer to the switch leg(the wire that goes to light fixture). if the dimmer has a white wire(nuetral wire) you will need to hook that up to the white wires in the wall box....CAUTION!!! when removing the old 1 pole switch, there should only be 2 wires and possibly a green or bare copper ground wire attached to it. if either of the 2 wires(not the ground) are white, IT IS MISLABLED OR MISCOLORED. DO NOT hook the dimmers white wire to it cuz it will fry the dimmer. If this is the case, then most likley you do not have a nuetral in the wall box but look anyway for a couple of white wires tied together with a wire nut and stuffed in the back of the box. if you find those than most likely thats your neutral(check with a wiggy or meter to be sure) and thats where the dimmers white wire goes. hook up the dimmers green wire to a green or bare copper wire in the wall box and then put a wire nut on the dimmers red w/white stripe wire.
Feb 16, 2014 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
I replaced a standard single pole light switch with a lutron Meastro dimmer switch with remote. It does not work. I replaced the standard switch and all was good. This circuit is on the same line a gfci...
Hello. There could be a couple of possibilities. First is the simplest to verify, is it a Companion Dimmer, Standard Dimmer switches or a 600W or 1000W Maestro Wireless Multi-location Dimmer. The Maestro Companion Dimmers can not be used individually, as they do not control a load, and must be used along with a Maestro or Maestro Wireless Multi-location Dimmer. The Campanion Dimmers are also a line/low voltage rating, and rated for incandescent and halogen but may not handle some flourescent fixtures. The other thing I can think of is that you may have interfearence from another item. They are radio frequency (RF) devices that communicate together for wireless control of lights. Here's two links that may be of some help, the second has downloadable install instructions.
http://www.smarthome.com/6601LA/Lutron-MA-R-LA-Maestro-Companion-Dimmer-Switch-Light-Almond/p.aspx
http://www.prolighting.com/lumamaprsmre.html
Hope this helps out, don't forget to rate this answer.
Thank You,
Richard
Mar 14, 2011 | Lutron SCR-20-GFCI - Dimmer Controls -...
How do I wire up a Maestro Lutron MAW-603-RH dimmer in a 4-way situation?
If you bought the 3-way package, there should've been two products included: the MA-600- and the MA-R. First of all, if this is a four way circuit, that means you currently have at least three switch locations. The package you bought takes cares of two of those locations, but to get the third, you need another MA-R. If there are more locations than that, each additional location requires an MA-R.
It doesn't matter which product (the MA-600 or the MA-R) you put at each location. They all wire the same.
At the 3-way locations (ends of the lighting circuit), install the dimmers just like you would a standard 3-way switch. The only thing I caution you, make sure that the blue screw on the dimmer is connected to one of the traveller wires going to the next switch box. Also note what color wire its attached to - because when you go to that next switch box, the blue screw of that dimmer needs to tie to that same wire. At the 4-way switch box, the most important thing to remember is this.... make sure all the blue screws are connected together (which is why its important to know WHICH wire is connected to the 3-way switches).
As long as you have enough product and you tie the blue screws together, it should work.
Nov 11, 2010 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
I have a DL-3PSLHW-WH switch with no wiring diagram. It is single pole or 3-way. Need diagram.
You posted under Lutron 3-way dimmer.
You didn't say the number of screw terminals on device or color of those screws.
If your device has two brass screws, then it is single pole.
If your device has 2 brass screws and 1 dark screw, then device is 3-way
If you are replacing 3-way switch, identify wire on dark screw >> connect this wire to dark screw on dimmer. Other two wires connect to either brass screw.
If device has wires instead of screws, the color of those wires is an important clue.
Answer back with the colors of those wire and it is easier to help.
Different dimmers are suitable for different types of lighting.
In an effort to help you, I searched my files for Lutron dimmers.
Lutron has 17 dimmer types, with numerous models under each type
They don't show DL-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Lutron has NT-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/NovaTDimmer/Pages/ModelNumbers.aspx
The NT-3PS is a 3-way dimmer.
Here is wiring manual:
http://www.lutron.com/TechnicalDocumentLibrary/wallbox_wiring_6_7.pdf
If the help above does not get you going, answer back with more information and we can help.
Oct 24, 2010 | Lutron Dalia 3Way Dimmer 600W- White -...
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
I purchased a replacement MA 600 3 way dimmer. The old ones had wires, this one screws. Can you tell me how they map?
http://lutron.com/CMS400/page.aspx?id=16977
The black screw is the common (either power or switch leg depending on which side of the 3-way you are working with), the brass screw is one traveler and the blue screw is a low voltage communication lead (second traveler). I have attached a link to Lutron's wiring diagram pages, just select your dimmer.
Nov 29, 2009 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Lutron maestro IR remote control wireless dimmer won't work
http://www.lutron.com/wallboxvideos/maestro_ir_remote_programming.html
If you have followed the programming instructions, the only thing that might be wrong would be the power wire and switch leg wire may be installed on the wrong screws on the back of the device. Be sure that the wire bringing power "INTO" the box is connected to the "Black" screw on the dimmer and the wire going "OUT" to the light fixture is on the "Gold" or "Brass" colored. If these are backwards the dimmer will probably work, but the IR would not. If you are positive it's wired correctly and the IR remote still won't sync up, call the 800 number at the end of the attached video for Lutron Technical Support. Good Luck!
Nov 09, 2009 | Maestro Electrical Supplies
Installed 3 way dimmer - when turning off at 2nd location can not control dimming from first location until second location has been turned off then able to control dimming at first location - pass &...
Some dimmers are specific to which end of the 3-way system they are installed on "Power" or "Switch Leg". The way you can test which side is the power and switch leg is to test the wire on the "Black" screw of the switch (common) to ground with the lights OFF. If you have power on the "common" screw with the lights OFF it's the power end, if you have no power on the "common" screw with the lights OFF it's the switch leg end. Verify that you have the dimmer on the side specified in the instructions (switch leg). Sounds to me like you have it on the "Power End" so you are dimming on of the travelers instead of the light. That is why it is dimmed in one position and not in the other. (See page N-23)
http://www.passandseymour.com/pdf/N.pdf
Oct 14, 2009 | Pass & Seymour #T603WV 600W White 3WY...
Electrical Supplies Logo
102 people viewed this question
Top Maestro Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
