Question about Boating
Raymarine st60 dept transducer
My unit is showing -- how do i clean transducer how do i reset it and make sure there are no issue. if transducer is bad, is there repair kit?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
No you buy a new one there a sealed unit cant take them apart
Posted on Dec 19, 2013
  • 5 Answers
SOURCE: Raymarine St40 trouble
50/200 combination will work fine but 170/200 may be a little close in frequency and give you some trouble. "May be OK" doesn't leave me with a lot of confidence.
Posted on Jul 24, 2008
SOURCE: a65 Raymarine combo gps plotter fishfinder
changes.
Posted on Jan 09, 2009
the kowalski
  • 86 Answers
SOURCE: Owners manual
You can find the owners manual here:http://www.raymarine.co.uk/products/instruments/st60-plus-series/e22075-p/?esctl369867_asset=6656
Posted on Jun 03, 2009
MarineTech1
  • 76 Answers
SOURCE: my raymarine ds600x is losing bottom at 120
The depth loosing bottom would certainly indicate that you may have growth fouling the transducer, however the sea temp 220 degrees indicates possibly a different problem. Start by being sure the transducer is squeaky clean and see what that does for you.
Posted on Aug 12, 2009
SOURCE: Hi I have an Apelco 530 fishfinder/gps and need a
I have a new one. If you still need one, please contact
nakdogan@t-online.de
Posted on Oct 21, 2010
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
I have a A22012 ST60 wind vane I need an new transducer what part number should I look for for replacement
Hi Greg!
What you're looking for is an E22078.
Here is a link from binnacle.ca, but I'm sure you can find them cheaper if you look around.
Hope this helps.
-Steve
RAYMARINE ST60 PLUS WIND TRANSDUCER MASTHEAD E22078
Jan 23, 2015 | Boating
Display only showing dashes ----- I have voltages on the 5 core cable from transducer to back of display .... what are correct values for these?
Try to identify if the fault is in the masthead unit or the display by using a known good unit ,or masthead or display.
Then have it repaired.
Feb 28, 2011 | Raymarine St60 Wind Vane Ducer E22078
The self-closing valve on our 13 year old ST60 speed transducer now only closes sometimes when the blank or impellor sensor is removed. We suspect that a spring is missing. We need a raymarine spare part...
Spring not available must buy housing and replace or if it is sleeved, buy housing and slide in new sleeve there are two different types, one has a removable sleeve with flapper
A long shot would be Raymarine tech support 800-539-5539
I can sell you the part 847-746-0100 technicalmarine.com
Feb 20, 2010 | Raymarine St60 Plus Package, Includes...
My raymarine ds600x is losing bottom at 120 feet...water temperature is at 220. I have a thru hull transducer...Im wondering if my ducer is fouled up with marine growth or is it a bad ducer or head unit.....
Jul 23, 2009 | Raymarine Ds600x Fishfinder Display Only
Picture freeze
It sounds like a software issue. If the depth still shows numbers and not dashes, that indicate that the DSM and trandsucer is working. Be sure that you have the most recent software for the E120 and for the DSM. You can find info about the current software and how to load it on Raymarine's website. It is important to perform a factory reset once the new software is loaded. If that doesnt solve your trouble, you will need to consult Raymarine's tech support dept.
Nov 27, 2008 | Raymarine Dsm30 Digital Sounder Module
Raymarine ST50
http://www.defender.com/product.jsp?path=-1|344|295761|301233|320702|746011&id=823240
Oct 19, 2008 | Raymarine ST60 A22012-P GPS Receiver
Raymarine Compatability
Yes. The shorty transducers that normally ship with the ST40 series instruments should be interchangeable with longer stem ST60 series ducers.
Jun 09, 2008 | GPS
St60 wind instrument
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Dec 13, 2007 | Raymarine ST60 A22012-P GPS Receiver
Boating Logo
63 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
