Question about Dryers
My lg dryer dlg8388nm starts up and the flame stops after 20 seconds
SOURCE: Whirlpool gas dryer model #
The flame sensor is probably bad. This is located on the side of the tube the flame is in. Has two wires going to it. Try to short it out and see if the flame stays lit. UNDER NO CIRCUMSTANCES OPERATE THIS DRYER WITH CLOTHES IN IT WITHOUT THE FLAME SENSOR IN PLACE!!!!! The other problem might be air flow. If the duct is blocked the flame will trigger the high limit switch. Take the hose off the back of the dryer and turn it on. There should be a lot of air flow. If there is and the flame stays on the duct hose or outlet is clogged.
Posted on Jun 29, 2008
docjohn174
  • 943 Answers
SOURCE: KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Posted on Oct 03, 2008
  • 14 Answers
SOURCE: Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Posted on Jan 03, 2009
  • 79 Answers
SOURCE: flame goes out
If this unit has a pilot flame, the breather around the pilot flame has become dusty. The best way to clean it out is with high pressure air.
It wouldn't hurt to clean with high pressure air anyhow.
See how that goes.
Posted on Apr 26, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool model GGQ8858EQ1 gas dryer starts, gets
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
Posted on May 05, 2009
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Mosley@hughes.netI have a lg model dlg8388nm that won't run unless i turn off most item's in the house drawing electric?
Call an electrician or the power company... you have major problems with the electrical service coming into you home...there is a very bad connection somewhere...
heatman101
Aug 13, 2011 | LG Dryers
I have a model LDG712 gas dryer. The flame ignites and burns for about 20 seconds. The flame then stops burning and it about 1 minute and 30 seconds or more before it lights again. The glow bar...
The flame should cycle on for about 50 seconds on the first cycle and approx 20 sec each additional cycle. I would check your airflow out of the dryer it my be restricted not allowing the flame to pull through the burner tube causing the unit to "short cycle". Its not likely a thermostat issue but if you were to replace a thermostat I would replace the cycling thermostat should be part number 3387134. Hope this helps.
_MJ_
Dec 15, 2010 | Maytag Dryers
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Dryer won't dry
That is a bad gas valve, change it.
Sep 02, 2009 | Dryers
Flame goes out
See how that goes.
Apr 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Jan 03, 2009 | Kenmore 73952 Gas Dryer
KENMORE gas dryer
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Oct 03, 2008 | Kenmore 73932 Gas Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
