Canon 5350 i have just refilled my inkj cartridge and it doesnt recognise one of the large black cartridges ive tryed cleaning the sensors ive trying emptying the cartridge refilling it. everything and it still doesnt recognise the cartridge. then i tryed taking other ones out to see if it recognises any of them and even when it has been taken out they are still recognised as being there and tha black one which is still in isnt recognised. what can i do ??
SOURCE: Refilled cartridge not recognised by printer (canon PIXMA MP210)
I held down the stop butten for five seconds and now it seems to work fine. Perhaps this could help you.
Posted on Dec 19, 2007
SOURCE: CARTRIDGE REPLACEMENT NOT RECOGNISED
Thank you, but Cartridge World decided that it was a damaged cartridge and replaced it.
Posted on Apr 29, 2009
  • 4 Answers
SOURCE: HP 4280 - new black refilled cartridge not recognised
hi steve... the solution to your problem is a costly one. the printer keeps in memory 2 cartidges for colour and 2 for black, when a third is placed in the printer the first one is deleted out of memory same for the colouredand same for the black... therefore you need 3 cartridges each to do the trick.
eg. if you want to use colour cartridge #2 then 1st place colour nuber 1 or 3, then turn it on let it reads, then open door and place in colour number 3 or 1 let it read, then take out and place in coulur number 2 and it will see it as new
Posted on May 01, 2009
  • 159 Answers
SOURCE: Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Posted on Dec 28, 2009
Dicedonions
  • 118 Answers
SOURCE: My x4650 is not recognising when I refill the
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. or take cartridge out and put back in to insure in securely.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
Ive just filled my ink cartridges but have the following error message when trying to print: (see add details section)
You need to reset the chip in the cartridge that tells the printer when it's low. The part can be found on sites that sell refill kits.
Aug 07, 2015 | Canon PIXMA MG3150 Inkjet Multifunction...
Prints are green
bad or poorly refilled ink cartridge, and possible color misalignment at setup of new ink cartridge. Redo your ink settings thru ur alignment and cleaning service for your cartridge and try it again. Ive had poorly refilled ink cartridges and do reely suspect urs as having been poorly refilled...
Jan 18, 2010 | Canon SELPHY DS810 InkJet Photo Printer
My canon 17oo pixma wont recognise the 40 black
did u changed / replaced the cartridge with original spare or refilled it??
do not panic..this kind of problem often follows with (esp. an unbranded) cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed....
if all the above fails, then it may b a defective or demo cartridge..!!
and call ur system admin....
Nov 16, 2009 | Canon Office Equipment & Supplies
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Apr 28, 2009 | Canon PIXMA iP1600 Printer
Canon INkjet MP170 not recognising cartridges
make sure the contacts are clean! get a new cartridge, and it if does the same thing...its UR printer.
Dec 19, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon Pixma MP950 Ink Refill Error
replace the cartridge with a Canon as the chip has gone on the cartridge.
this is the only way around it with the mp950.
This is to stop them being refilled
May 22, 2008 | Canon Pixma MP950 All-In-One InkJet...
I have a canon mp 210
As the printer companies do not support refilled cartridges,B cose these cartridges inbuilt sensors which is ink sensitive,Once empty they do not work. Try using new cartridge from canon it should work
Mar 05, 2008 | Lexmark X5150 All-In-One InkJet Printer
Nov 14, 2007 | Office Equipment & Supplies
24 people viewed this question
k24674
