Question about Equity Time USA 31215 Wireless Outdoor Thermometer
Since we have changed batteries, the clock beeps often. We need help turning off the beeping.
Dell Studio XPS System 435MT beeps?
Here is a list of beeps that can help you:
1 beep BIOS ROM checksum in progress or System board failure
2 beep No memory modules detected
3 beep System board failure. Power LED is blinking amber
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller test failure
4 beep Memory failure
5 beep CMOS battery failure
6 beep Video card failure
AK
Jul 17, 2014 | Dell Computers & Internet
4 beeps wont turn on screen stays black
Four beeps indicates -
The system clock/timer IC has failed or there is a memory error in the first bank of memory.
Try replacing the CMOS/RTC battery (consult your manual), if it does not help, you might need a new motherboard.
Good Luck!
May 29, 2012 | Toshiba Satellite M45-S165 Notebook
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Every hour my detector beeps and the green lights flashing is it carbon nonoxide or smoke or battery??
If it only beeps once and then pauses, the batteries are suspect. The batteries should be replaced twice each year. I like to change them when we change the clocks back and forth.
I hope that this helps.
asnowman
Hint you can test them with a match (blow it out) and let the smoke rise into the detector. I recommend that this be done at lease once a year.
Hope this helps
asnowman
Apr 17, 2010 | First Alert SA302 Dual System Smoke...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Changed mem speed lower then got a beep and black screen
Reset the BIOS.
Plan A: Look in your motherboard manual and find the location of a "CMOS Reset" jumper. Move the jumper from its current position to its other configuration for five seconds. Then, put it back the way it was and turn it on. If that doesn't work use Plan B :)
Plan B: Take the clock battery out, and short (touch) the battery holder metal contacts with a switch. Put the battery back in. Turn it on and see if it works.
All your BIOS settings will be reset to default after this, including your clock.
May 15, 2009 | Dell (E210882) Motherboard
My clock AJ 3010 clock radio gives off an electronic sound every 10 to 20 minutes. It's like a warning sound you get from a smoke alarm when a battery is running low. I've tried replacing the batteries but...
If you want to turn off all system beeps (like the ones that go through your computers' internal speaker ):
  1. Go to Start-->Run-->Type Regedit.
  2. Go to HKEY_CURRENT_USER\Control Panel\Sound
  3. Edit the key Beep and give it a value of No
This will help you to turn off system beeps.
Apr 20, 2009 | Philips AJ3010 Clock Radio
Stop the beeping!
Try resetting the clock, by pressing the small button on the side of the clock, or get new batteries.
Feb 18, 2018 | Oregon Scientific PSM06A-G Clock Radio
Hourly beep
click alarm set button the off/reset button should see "00" icon on screen go off or on
May 17, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Equity Time USA 31215 Wireless Outdoor Thermometer Logo
35 people viewed this question
Top Equity Time USA Measuring Tools & Sensors Experts
George Merkley
George Merkley
rich2481
Are you an Equity Time USA Measuring Tool and Sensor Expert? Answer questions, earn points and help others
