Question about 2wire PC Port Phoneline HomePNA 10Mbps USB Adapter
Can't connect to internet with 2wire PC port
Is this product Vista compatible? Just got a new computer with Vista and now my 2wire PC port does not work. It is fairly old, might that be the problem or Windows Vista?
  • mapmaker Apr 07, 2008
    I have the same problem. I hate Vista. This is Microsofts way of making us go out and by all new hardware and software.
    As far as the PC port, I let the "c" drive look for and install the driver. It will get you online, but computer will eventually shut down and reboot with an error stating incompatability.
  • stussy Dec 31, 2008
    I have the 2wire router, use the usb cable on a pc with vista and the ethernet cable on a pc with ubuntu.
  • 12,061 Answers
Yes U R right. this is most probably a "Driver" problem. You could try installing the software in "Administrator Mode".. with "Compatability Mode" set for XP. If this doesn't work.. then ya may have to try to contact the manufacturer and ask for a compatable driver for Vista.
Posted on Aug 31, 2007
SOURCE:
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
I need drivers for Vista
hi
plz go thru the link below
http://www.nodevice.com/driver/company/2wire.html
and check it whether it is a trusted site and then u can scan it for your virus. u can even consult with ur comp vendor for its security
thanx and regards
sukhiii
Jul 25, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Connected but no internet
del everything in %temp%, if you are using internet explorer, reset it back to factory by..in IE7 select,tools,internet options,go to advanced tab and click reset. Be advised, Vista is notoriously difficult when it comes to internet connection problems especially wireless.
www.aa1consulting.com
Jul 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I have a new Dell Insprion 530 and can't connect to the internet with my 2wire1000sw. I am receiving a driver error. No drivers are installed for my 2wire. Is there a way to get these drivers without...
Your new computer should have came with a resource cd for drivers, if not then you need to contact dell for support and have them provide you with a CD thaqt copntains all the drivers for your computer. You might want to have this anyway in case you need to troubleshoot your computer. I hope this info helps.
Mar 06, 2009 | Computers & Internet
New dell computer w/vista
set you pc to automatic assign IP address and DNS server under tcp/ip settings, your computer should acquire the correct settings from your 2wire.
Nov 15, 2008 | 2wire 1800HG Router (RG1800HG00)
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
No internet connection using wireless
i strongly recommend if you try calling your isp provider again, i blv they actually have specialist trained for 2wire connection, you just have to ask for them...vista still has compatibility issues, did your router worked wireless with other pc like xp?..i hope you'll have this resolved already...
Nov 27, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire pc adapter
If you go to the 2Wire site you will see that only 3 of the seven adapter products listed there have Vista drivers.
http://www.2wire.com/?p=331
If you have one of the Vista supported products, make sure you have the Vista driver.
If you do not, get one that is.
Oct 14, 2007 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
2wire PC Port Phoneline HomePNA 10Mbps USB Adapter Logo
1,456 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
