Sony laserdisc LDP-3600D manual
Dear sirs, I am looking for the sony laserdisc LDP-3600D manual and, if possible the remote control Can you help me ?
2 Suggested Answers
the q guy
  • 393 Answers
SOURCE: Looking for a replacement manual for a Jensen Universal Remote
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Posted on Apr 26, 2009
Panasonic lazerdisk player remote will no turn on the player
Is it possible that someone has either accidently or on purpose changed the remote code on the player.
Other problems include dropped remote, or dirt inside the buttons.
Jul 24, 2016 | Panasonic Multi Laserdisc Player Ag-ld30
3.3l engine. What are the probable causes of DTC P1495?
answer courtesy of engine codes .com Engine-Codes OBDII Code List P1495 Dodge
P1495 Dodge P1495 Dodge - EVAP Leak Detection Pump Solenoid Circuit Condition 3 ' Add Comment Possible causes
- Faulty Leak Detection Pump (LDP)
- Leak Detection Pump (LDP) harness is open or shorted
- Leak Detection Pump (LDP) poor electrical connection
What does this mean? When is the code detected?
Malfunction is detected when the Powertrain Control Module (PCM) detected the pump solenoid did not change status when activated,
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors
P1495 Dodge Description
The Evaporative emissions system is design to prevent the escape of fuel vapors from the fuel system. Leaks in the system, ca allow vapors to escape into the atmosphere. The leak detection system tests for EVAP system leaks and blockage.
During the self-diagnostics, the Powertrain Control Module (PCM) first checks the Leak Detection Pump (LDP) for electrical and mechanical faults. If the first checks pass, the PCM then uses the LDP to seal the vent valve and pump air into the system to pressurize it. If a leak is present, the PCM will continue pumping the LDP to replace the air that leaks out. The PCM determines the size of the leak based on how fast/long it must pump the LDP as it tries to maintain pressure in the system.
Read more: http://engine-codes.com/p1495_dodge.html#ixzz3iQ8P3JII P1495 Dodge EVAP Leak Detection Pump Solenoid Circuit Condition
Aug 10, 2015 | Dodge Caravan Cars & Trucks
Code 1475 1471 1477 1472 and wont start sonetimes
This should give you some problems to look up:
P1471 EVAP Emission Control LDP Circuit Short to B+
Possible failuer of OBD II Fault code P1472
  • Signal line short
  • Sensor failure
P1472 EVAP Emission Control LDP Circuit Short to Ground
P1475 EVAP Emission Control LDP Circuit Malfunction/Signal Circuit Open
P1477 EVAP Emission Control LDP Circuit Malfunction
Apr 07, 2015 | Cars & Trucks
P1495 on 2000 dodge stratus 2.4 l engine how to fix the problem
The code is telling you that you have a problem with the pump.
DTC P1495 - LEAK DETECTION PUMP SOLENOID CIRCUIT
WHEN MONITORED Ignition on and battery voltage greater than 10.4 volts .
SET CONDITION The state of the solenoid circuit does not change.
POSSIBLE CAUSES Fused ignition switch output circuit open
Leak detection pump defective LDP solenoid circuit wiring harness observable def LDP solenoid ckt wiring harness intermittent def LDP solenoid control circuit short to ground Leak detection pump solenoid control circuit open Powertrain control module defective
During evaporative system diagnosis, Leak Detection Pumps have mistakenly been replaced. A thorough inspection for pinched, kinked, or disconnected supply vacuum lines (as currently listed in the Powertrain Diagnostic Procedures) is a critical step in diagnosing DTC P1494 (LDP SW OR MECHANICAL FAULT). Additionally, the other evaporative leak faults (DTC P0442 - SMALL LEAK, P0455 - LARGE LEAK, and P0456 - VERY SMALL LEAK) should have the supply vacuum lines examined for pinches or kinks prior to any LDP component replacement.
The supply vacuum lines should be checked from the engine compartment all the way to the fuel tank, including the LDP and purge system.
NOTE: VERIFY ALL RELATED SUPPLY VACUUM LINE ROUTINGS FOR PINCHES, KINKS, OR DISCONNECTION'S BEFORE REPLACING LDP SYSTEM COMPONENTS.
Hope this helps, also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Apr 16, 2012 | Cars & Trucks
I have a rm-p311 remote can it be programed to run a newer unit
Sony remotes keep the same codes for all there tvs. It will run older as well as the newest tvs. Hope this helps.
May 10, 2011 | Sony RM-P311 Remote Control
I want to program my remote to dvd
Hi there. You can set up a Watch DVD Activity by doing the following:
1. Click "Add Activity" 2, Select "No - manually..." 3. Seect "Watch DVD or Laserdisc" 4. Select "Watch a DVD ( DVD player)" 5. Click NEXT, and go through the setup. 6. Update the remote.
Hope that helps :)
Feb 25, 2010 | Logitech Harmony One Advanced Universal...
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
Nov 17, 2008 | RCA Universal Remote Control
RCA Universal Remote Code
Here are the codes for Philips. If these do not work you have to use the code search feature.
Philips........002,006,007,010,011,013,016, 033,035,037,038,043,066,073
100 times).
for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-7.
Nov 12, 2008 | RCA Universal Remote Control
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
