Question about Toro Garden
Toro 6.75 mower has a recessed plug impossible to remove with socket or wrench. Model 20371 but I know there are other models of Toro with this design.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toro Master
  • 1,917 Answers
If your wanting to chang oil the shops tilt it on there side and drain threw filler pipe they dont mess with the plug
Posted on Jun 07, 2014
  • 77 Answers
SOURCE: My Toro Lawn Mower Model 20016 no longer moves
Your transmission is bad,need to have one ordered.
Posted on Aug 12, 2009
  • 67 Answers
SOURCE: How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Posted on Sep 01, 2009
vincob
  • 718 Answers
SOURCE: Toro Model 20070 will not start. I have spark,but
Check the gas and gas tank, you might have water in the gas.
Posted on Sep 26, 2009
  • 28 Answers
SOURCE: gaining access to change a drive belt on mower
the belt cover should have screws with the heads on top of the deck, then there is a guide which keeps the belt in the engine pulley with 2 or 3 bolts you might be able ot get it on the gearbox with just those off and a bit of prying etc.
Posted on Oct 03, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
How to remove and replace a rear wheel on toro lawn mower model #20371?
Look and see how the other side is attached and duplicate
Sep 02, 2014 | Toro Garden
Toro lawn mower troubleshooting
A dirty air filter is a common cause of this. Give it a look. Otherwise a replacement carb would be the route to take.
Aug 21, 2014 | Toro 20371 - 22In OHV Recycler High Wheel...
What spark plug wrench is used to remove the spark plug on a TORO 38624w snowblower?
it is prob a 13/16 this is the most common most of the time you cannot get a wrench on a plug but a socket , if it is smaller then it is a 5/8 lefty loosie righty tighty do not over tighten the plug
Jan 20, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
Toro spark plug is recessed and can't be removed
Use a chainsaw combi-spanner, they are designed for accessing spark plugs that are hard to reach.
Jul 30, 2013 | Toro Garden
I have a new model 20371 tor self propelled mower. Used it once. Won't start
Change the plug.
Check coil / wire.
Clean or replace air filter.
Check fuel tank for debri / grass or dirt.
If there is grass or debri in the gas tank, you need to go through the carbruetor because the jets are possibly clogged......
Hope this works...
Apr 21, 2013 | Toro Lawn Mower With Toro Power Tools
How do I change the oil on my Toro Personal Pace mower? Do I need to remove some cover?
The oil drain plug should be under the deck. You probably have a bracket in the way that you need to remove. Once you remove the bracket you should be able to access the drain plug. Piece of advice do not cross thread the drain plug and do not over tighten it. You should only turn the drain plug 1/2 a wrench turn above finger tight.
Jun 15, 2011 | Toro Power Lawn Mower
Toro walk behind model 20016. The starter rope did not break it just won't pull out??? HELP
Remove the rope case and see if it is the mower -also - remove the spark plug and try it - also - - after removing the spark plug - also -try spinning the blade. If you remove the top you will see the problem sooner.
Gary @ Fix Ya
Sep 09, 2010 | Toro Lawn Mower With Toro Power Tools
Is the bolt holding the blade reverse threaded or conventional?
it's a 5/8" socket use air impact wrench to remove and install if you do not have these tools available take it to a reputable service station your safety could depend on it.
Apr 12, 2010 | Toro Lawn Mower With Toro Power Tools
Where do I have access to drain oil from my TORO GTS2 lawnmower?
There are two ways to drain the oil. One is to tilt the lawnmower and drain the oil from the oil fill which is really a pain in the ****. The other is easy; here is what you do. First, disconnect the spark plug to ensure the mower cannot start (I don't have to tell you what effect a turning mower blade can have on human digits), and raise the mower up; you can use an ATV jack or you can get someone to help you set it on saw horses or you can simply raise the front by pushing the handle to the ground. On the bottom of the deck you will see a drain plug, you can't miss it, it's a square fitting...you can use a socket extension and wrench to pull it...make sure you have a receptacle to catch the old oil before you remove that plug, you don't want oil all over your garage floor (ask me how I know that! lol). Once the oil is drained completely, meaning there is nothing but drops coming out, clean the drain plug and re-install it. Now you can lower you rmower and fill the crankcase with fresh oil!
Oct 19, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
