Question about Exercise & Fitness
Treadclimber t 20 has error code H11 - Exercise & Fitness
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
Estp
If you wish to get some details treadmill error codes and maintenance ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2014 | Bowflex Treadclimber
Is there a list of default codes for treadclimber error codes?
yes but only in your instruction manual.
go and download for free www.fitness.manualsonline. or www.retrevo.com or www.iconservice.com or www.manualsfactory.com
God bless you
May 09, 2012 | Bowflex Treadclimber
Bowflex treadclimber gives error code h13 h24
this a problem with a bad design from a factory. You must call to service support a explain this error. Is a problem,with a PROM AND EPROM.
However you can try to RUN the software calibration for diagnose, and troubleshootingl.
God bless you
My bowflex treadclimber tc 20 is putting out error codes H03,H13,H24 whats wrong
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
Apr 14, 2012 | Bowflex Treadclimber
Remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Sep 19, 2009 | Heating & Cooling
Error Code E1
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Jan 24, 2009 | Bowflex Treadclimber
Error code 6 on tape drive 3580 H11
The Drives might be having read/write problem.
I sugguest you contact nsasia@hotmail.com they fixed my drive with the same problem.
Dec 03, 2008 | IBM 3580 Model H11 (3580-H11) Ultrium Tape...
Exercise & Fitness Logo
51 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
