Question about Intel Computers & Internet
Starts heating heat stops - Intel Computers & Internet
Starts then stops
Check for heat being generated before it stops. If you have heat then it could be the thermal protection that is stopping the machine because it may have an airflow issue. If it is not generating heat then the issue is the heating element. In any case you should unplug the machine and take the bottom panel off under the door and clean it out. If you have never done this, the build up of lint on the motor could be causing an over heating issue too.
Apr 08, 2014 | General Electric Profile DPVH890EJMV 7.5...
Heat pump condenser fan starts then stops in cold weather
does it heat ok? this is normal in cold temp as fam is not needed in cold temps. try it on warmer day and it will probably run. dont think you have a problem
Jan 30, 2014 | Heating & Cooling
On volkswagen beetle 2006 when car stops on red light heating system stops workin start blowing cold air. and ven car start moving heat comes back and starts heating again. They told me it is air in...
sounds like heater core may need to be cleaned... volks wagons have heating systems that sometimes do very strange things for no apparent reason....
Dec 28, 2013 | 1998 Volkswagen Beetle
Furnace won't stop running
Jump out limit switch blower should stop and inducer should come on then the heating sequences should start from there
Nov 28, 2013 | Carrier 52CQ-312-4 Comfort Series Heat...
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
It just stopped heating
If you have a gas dryer the burner is ignited by a eletroniic ignitor. It will make a ckicking noise upon starting it when set in the heat mode. You should hear the click or clicking noise it makes within 30 seconds after starting the dryer. If no click is heard, replace the spark ignitor
Mar 30, 2010 | Dryers
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore gas Dryer Heats at start then stops heating
Usually problem like this with electrical solenoids located on the top of gas valve inside the dryer. They need to be replace.
Dec 08, 2008 | Kenmore 73952 Gas Dryer
Drum runs, but no heat
i would first look at the heating element. check for continuity.
Feb 08, 2008 | Dryers
Computers & Internet Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
