Becken washing machine spin programme
Instructions in Spanish, need to know which symbol to use for a short wash cycle and what symbol for just a top speed spin.
SOURCE: Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Posted on Jan 02, 2008
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Posted on Mar 17, 2010
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
Wash comes out wet on highest spin speed. The drum spin speed doesn't appear to be fast enough. Is there an adjustment for the spin speed?
Hello, the trouble here is with the spin control board. To confirm this pop the top off and get the tech sheet from inside the machine. next run the diagnostic cycle using the instructions on the sheet. this should confirm the spin control board is bad(sometimes called the motor control board) Hope this helps! Mike
Nov 03, 2009 | Siemens WFXD8400UC Front Load Washer
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer agitates for a time then sputters. Does not spin
In sounds to me like you have a motor issue. We have found that on these particuliar models, that the motor tries to run in both speeds at the same time. If you already replaced the control board, then you will have to get a new motor kit. This kit includes directions as well as a new wiring harness and start capacitor. You would have to remove the old motor and rewire the wiring harness (instructions included with the kit) and add the new start capacitor (instructions also included). Job is'nt really that hard to do. Front cover would be all you would need to remove to get to all the parts. Good luck and let me know how it turns out or if you need any additional help. Jim
Sep 05, 2007 | Washing Machines
Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Apr 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
