Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
My Exilim camera!
Hi, i came to NYC for the summer and bought myself the camera, which worked fine for a few days. but 2days ago, i charged it overnight and the next day, it didnt switch on....assuming it wasnt charged i attempted to charge the battery only to get a blinking red signal. so today i went to a store where they had the exact camera just to check whether its my battery or the actual camera (which i found hard to believe bcos i havent dropped or mistreated it)but the salesman put in a battery from another exilim only to find the camera still wouldnt turn on! Mayb i will take my charger to be cheked tommorow but is ther any type of reset method or is my camera doomed? Thanks
  • 1 more comment
  • Anonymous Dec 18, 2007
    omg! my daughter was just telling me that the exact same thing happened to her camera. she has only used it about 10 times.
    did you ever figure out the problem?
  • eveeya Apr 13, 2008
    I'm having the exact same problem - i've charged my camera battery fine before, and if i'm honest, haven't used my camera that many times.
    however, the battery won't charge for some reason - however long i leave it, and the charger light continues to flash red.
    help!
  • Anonymous Apr 23, 2008
    I am having the same blinking red light problem.. I've used my camera only a handful of times, but now the battery won't charge and it won't turn on.
Make sure you put it in the right way, the battery fits both ways but will only work if it's inserted correctly
Posted on Apr 24, 2008
  • 477 Answers
If this happens allot of the times you have to remove the battery from the camera for 24 hr so the camera's compositors can discharge all the way and not it is not the circuit board. Some time the circuit over loads and has to be discharged because of the polarity the electricity is travailing thought the circuits now I know diodes are suppose to prevent this but it is a common problem. hope this helps.
Posted on Apr 10, 2008
SOURCE:
Battery won't hold a full charge
batteries don't have a life forever. And no one can predict the life time of a battery.
So many factors influence the lifetime. But if it is draining very fast, this mostly means it has reached the end of life. If the camera does not get excessive hot, it has nothing to do with the camera. It is just you need a new battery.
To keep a battery in shape for a longer time you should charge it also when the camera is not used. Like at least 4 times a year. Always charge the battery a day before you plan to use it. Don't over charge, like charging it every day. Don't leave it in the bright sun or on a hot place.
A new battery, should be charged and discharged a few times, before it gets a full charge.
The "New" battery you bought, could be in stock for a long time. Special when you could buy it very cheap.
Perhaps in a few days you say, he the battery works fine now. But if you did charge it 3 or more times and it still does not hold a charge. send the battery back (I hope you bought one with warranty)
Aug 14, 2014 | Casio EXILIM ZOOM EX-Z60 Digital Camera
I have a Casio Exilim camera which was working fine. I went to use it a few days ago and there was no power. The battery appeared to not accept a charge so I figured it was past its sell by. I bought a new...
Casio cameras use generally chinese batteries. They are mostly under an acceptable quality. So the battery you have bought may be out of order. I do not think that your camera is out of order.
Try another working battery.
If it will not work then send me a comment and lets control additionally.
Jun 03, 2010 | Casio Exilim EXZ75 Digital Camera
Fan cool fridge working 3years bought new 2days ago starts blowin
Good day,
I don't understand your caption..........
Fan cool fridge working 3years bought new 2days ago... However, it sounds as if the compressor is trying to start and cannot.
If the machine is under 5 years of age, the compressor is under factory warranty.
There is a relay, capacitor, and overload which are connected to the side of the compressor after removing the back bottom rear cover.
These items could be removed and taken to an appliance parts house, where they would be glad to test them for you. Replace failed parts.
However, if it is under 5 years of age, I would recommend you call for factory warranty service. They may have to charge you for one of these parts, but since it could be a failed compressor, and not the starting components it is better to let them service it and maintain the balance of your compressor warranty.
Jan 29, 2010 | Jenn-Air JBL2086HES Bottom Freezer...
Casio Exilim EX-S880 will not turn on
The problem is the spring terminals inside the camera are not making good contact with the battery. I had to use a screw driver and gently push them to the left to make better contact with the battery terminals. There are three connections. I stress that you be gentle. This not the long term fix but you will be able to take pictures in the short term.
Feb 25, 2009 | Casio Exilim EX-S880 Digital Camera
I have a casio exilim EX-Z60 the mians battery charger flashes constantly red when I place in my battery, but does not charge the battery, can you advise please
I have a casio exilim ex-z60 which I bought 2 yrs ago. I've had problems with my flash going off each time I turned on and off the camera, about 5 months ago. Now the flash does not work. Need help on how to restore the flash bulb or battery in the camera.
Jul 28, 2008 | Casio Exilim EX-Z57 Digital Camera
Exilim EX-Z75 dead battery
Has anyone found a solution to this? I have the same issue!
Jul 14, 2008 | Casio Exilim EX-Z750 Digital Camera
Overexposure in sunlight
It's probably a faulty shutter. Take a look at my blog post to a possible solution.
May 29, 2008 | Casio Exilim EXZ1050 Digital Camera
It can't be switched on
What you all need to do is contact Tech Support and tell them you're having trouble with your battery. Casio will send one to you free of charge that has been tested and should work.
Nov 17, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
114 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
