Question about Mevotech 2005 - 2007 Chevrolet Optra Suspension Stabilizer Bar Link Kit Mevote
Chevy radio fuse 2005 optra
Fuse for radio
Chevy optra 2005 Front wiper stop working, rear wiper and washer spray still work------any fixes
Check the fuse for the front wipers. Only other idea is that the front motor has died.
Sep 07, 2014 | Cars & Trucks
Optra is leaking fluid from somewhere and is overheating, how can it be fixed
Have you checked all the hoses? Next time it heats up, open the hood, or look underneath and see where its coming from!
May 17, 2014 | Chevrolet Chevy Cars & Trucks
Have chevy optra 2005 manual trans. Gear shifter became loose
remove the boot around the shifter and tighten the linkage bolts.
Oct 15, 2013 | 2009 Chevrolet Optra 1.6
I need a 2005 chevy optra timing belt diagram
2005 Chevrolet Optra has four available engines: 1.4L (DOHC), 1.6L (L91), 1.8L (L79) and 2.0L (L34 GMDAT).
If you would like a belt routing diagram, it would be helpful if you would mention which of these engines your Optra is equipped with.
Jul 08, 2011 | Chevrolet Chevy Cars & Trucks
Radio code for 2004 chevy optra
what code do i use for a chevrolet optra 2004 radio code to unlock it
Oct 19, 2010 | Car Audio & Video
04 chev optraheadlights not working. new switch and drl module. drls working .no high or low beam.relays and fuses good
apparently there has been a Daewoo technical bulletin that says problems with low beam and DRL on some 2005-6 Optras caused by a melted wire in the s201 splice pack on the IP harness. If I knew where that was I might be able to fix the same problem on my Optra. Tried new light switch but no success.
Jan 16, 2010 | Daewoo Nubira Cars & Trucks
Radio code for chevy optra
I dont know about having it unlocked at the dealership but whenever i disconnect the battery and reconnect, i use the code 6361 and the system is up and running again. hope this helps
Mar 26, 2009 | Vehicle Parts & Accessories
2004 chevy optra belt
Here is AutoZone's manual page showing the routing.
Jan 12, 2009 | 2005 Chevrolet Aveo
Mevotech 2005 - 2007 Chevrolet Optra Suspension Stabilizer Bar Link Kit Mevote Logo
Top Mevotech GPS Experts
Are you a Mevotech GPS Expert? Answer questions, earn points and help others
