Question about Garmin GPS
New Garmin 760 Rv will not stay bright. Try to increase brightness but after a minute or two, will go back down to 20%.
  • 4 Answers
SOURCE: screen keeps fading
I don't know for sure if this will help but it's worth a try. Go to Start, control pannel, system, advanced, performance, settings, and click adjust for best performance. This is a Windows XP fix but the same thing may apply to older OS's (95, 98, 2000, ME, NT (although you may have to set it a diferent way). Many other things could be your problem but this is an easy thing to try.
Posted on Feb 04, 2007
snakehead
  • 1074 Answers
SOURCE: The picture is to bright
if you are a tech open the tv and turn down the brightness from off the flyback screen adjustment if that does not work then the flyback will have to be replaced.it is defected.good luck
Posted on Apr 19, 2007
  • 223 Answers
SOURCE: battery discharging quickly
I think you have a faulty battery so if you can replace it. If the problem still persists then the most likely cause is a faulty capacitor on the power supply board of the gps. If you can find a competant technician to fix it. Hope this helps.
Posted on Oct 03, 2008
SOURCE: Garmin 760 will not power on
I had the same problem and the only way I could get my unit working again was resetting by turning on and keeping finger on the screen then clicking 'yes' to 'reset all user data"
Posted on Nov 17, 2008
SOURCE: brightness on garmin forerunner 305
Use the mode buttion to cycle to the main menu to Settings to general to Display. here you can change the contrast. In my manual it is page 45
Posted on Jan 01, 2009
Garmin unviable 2597 display brightness keeps going back to 20%. How do I keep it at desired setting?
master reset the unit by powering it down, holding the bottom right corner and powering it back on. otherwise you may have a deffective unit. try a sofware update/ map update with express then call for an exchange
Jul 21, 2014 | Garmin nuvi 2597LMT 5" GPS Navigator -...
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Whenever my Dell Precision M6300 is ever on maximum brightness, the backlight goes dark after 1-2 seconds. The screen is fully functional, but the backlight simply isn't working. I can get the backlight to...
guess there is an larger issue with your notebook.....
you need to get the backlite changed, if you have chanaged the lite then there is a compatibility issue with the screen and the invertor board that's behind the LCD screen.
or the system is not supplying the correct current to the backlite / invertor board
a HW tech guy may solve your issue
Nov 18, 2010 | Dell Precision M6300 Mobile Notebook
Garmin touch screen locked. If the screen goes in power save mode, i.e. brightness dims, then touching screen produces beep acknowledgement and the brightness increases, but the screen does not recognize...
there is probably the problem of your garmin touch screen,you need to try to replace a new touch screen.
If you want to replace it,you can try to contact
msn/email:kingyijin@hotmail.com
probably she will give you good solution.
good luck
Dec 19, 2009 | Garmin Nuvi 660 GPS Receiver
I was given a garmin ique 3600 but i plug it in how do i know its charging
It lights up on top. Then the litle battery icon will show with a lightning bolt.
Nov 20, 2009 | Garmin iQue 3600 GPS Receiver
How do i make my screen brighter on presario v2000
Decrease Brightness (fn+f7) The fn+f7 hotkey decreases the brightness of the notebook screen. The longer you hold down the fn+f7 hotkey, the more the screen dims. Decreasing screen brightness conserves power. » To increase screen brightness, press the fn+f8 hotkey.
Increase Brightness (fn+f8) The fn+f8 hotkey increases the brightness of the notebook screen. The longer you hold down the fn+f8 hotkey, the more the screen brightens. » To decrease screen brightness, press the fn+f7 hotkey.
Nov 03, 2009 | HP Compaq Presario V2000 Notebook
Brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
Battery discharging quickly
Oct 03, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
I have a Garmin Nuvi 760. The end cap which screws in and holds the fuse in for the traffic receiver power cord is broken. Anyone knows where I can get a replacement part without buying another power...
This is a known problem with the 760 traffic receiver power cords. Call Garmin Customer Service (you may stay on hold for 20 minutes or so). When someone answers, explain the problem and they will most likely send you a replacement screw cap and fuse assembly for free.
Jun 12, 2008 | Garmin GPS
Increase brightness
Press and hold the Fn key while pressing the up arrow key to increase brightness, down arrow key to reduce brightness
Feb 06, 2008 | Computers & Internet
GPS Logo
54 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
