Whirlpool stylemaster 4213632
The wash cycle stops at the end of the first cycle, won't finish .
philbran
  • 242 Answers
SOURCE: washing machine does not spin
If the unit is making noise while set to spin but not spinning replace the motor coupling for the fix.
If the unit is silent when set to spin replace the lid switch for the fix.
Both are very common and not expensive plus easy to find online with the model number under the lid. Let me know if you have any other questions.
Phil
Posted on Apr 11, 2009
  • 56 Answers
SOURCE: we have a Whirlpool washer stylemaster 4213632
Probably a bad timer. $100 + for part alone.
Posted on Jun 13, 2009
  • 215 Answers
SOURCE: whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Posted on Feb 11, 2010
  • 183 Answers
SOURCE: Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Posted on Jan 03, 2012
pashsambam06
SOURCE: My washing machine won't finish its cycle?
try the reset again but turn the water off
Posted on Feb 25, 2012
Grinding noise in spin cycle
It sounds like the drain pump needs replacing, its bearings have failed or there is something from the wash jammed in it. But before you buy a new one, get the machine checked by an expert in case lots of parts are damaged.
Dec 20, 2013 | Whirlpool Washing Machines
I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
May 08, 2012 | Whirlpool Washing Machines
Won't finish cycle
If you can't see a clean out drain on the bottom panel pull the panel off (three screws on bottom)...you will see the drain pump unscrew the clean out (get a bucket) these models won't finish a cycle unless ALL the water is out. nine times out of ten this is the problem. Hope this helps.
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 4213632 wont drain water on perm press or delicate
Feb 11, 2010 | Washing Machines
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
Aug 26, 2009 | Whirlpool Washing Machines
Washing machine does not spin
Phil
Apr 11, 2009 | Whirlpool Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
