Question about Sewing Machines
435 will start but only will run for a few seconds. I changed plug, cleaned air filter, and replaced the fuel filter, but it still will only run for a few seconds. I have used this saw for two years and only started doing this this morning. I have always used 100% gasoline in this saw.
  • 24 Answers
Check your muffler it may need cleaning, or if it has a spark arrester on the muffler that will plug with carbon and do exactly what you describe. If that checks out and you have good compression, check your fuel supply line to the carburetor for cracks or fitting loose. If not that remove carburetor disassemble and clean, replace seals with new ones and try starting. Your problem should be fixed. If not you need a new carburetor.
Posted on Jul 31, 2013
My Bernina 801 sport will not sew. When I step on the foot pedal, nothing happens. Sometimes it will sew for a few seconds and then stop. I cleaned it out but still will not sew
There can be a few problems that match your inquiry. Pleas check the machine in the following logical order:
  1. The power cable can be defective....With the machine plugged in and un-threaded, step on the foot control to check for a motor run condition and at the same time wiggle the cables at the motor plug connection. If the machine runs/stops/runs and stops, it is likely that the cables and or plug are damaged. Replace the cable. If the cable is found to be good, go to step 2.
  2. Check the motor run condition by changing foot controls. If the machine runs without a run/stop problem, the original foot control will have to be rebuilt. If the foot control is found to be good, go to step 3. Step 3 is for a qualified technician level of competency only.
  3. Remove the power cable, back cover, motor belt, motor housing. Remove the closing plate on the back of the motor housing to inspect the motor brushes. If the carbon brushes have worn out, you will probably find some damage to the commutator bars due to the brush springs having arc-worn the commutator. Generally, this type of damage can be repaired with excellent results. Most of the time however, motor brushes are installed by a sewing machine repair person, but no effort is made to repair the damage by resurfacing the commutator to a precision cylindrical diameter. This being the case, new motor brushes will have a very short life and further damage to the motor is likely.. Amateur attempts are sometimes made by applying some sort of tool or sandpaper to the commutator while the motor is running in an attempt to resurface, but concentricity and cylindricity cannot be achieved in such a manner....If the motor brushes are good go to step 4.
  4. Examine the commutator bars on the motor armature carefully for any burned spots on the borders of the copper commutator bar insulators. If such burn spots are evident, the armature will have two or more dead spots. At this point, the motor should be replaced.
http://www.sewtechnical.com/
Jul 21, 2015 | Bernina Sewing Machines
Replace fuel filter f-250 gas truck
SAFETY FIRST!!! Keep all heat sources, sparks, and flames away from the work area. Remove either the fuel pump fuse or fuel pump relay. Start the engine a few times to remove the fuel pressure from the fuel filter. Wear safety glasses, have a fire extinguisher available, bring rags, and a drain bucket too. After the fuel pressure is relieved, located the fuel filter on the inside of the driver's side frame rail. In a controlled manner, remove the retaining clips and slowly pull the fuel lines away from the fuel filter. Don't force them. Don't stress them to the point that they may break. Do not kink the fuel lines. After removing the fuel lines. You will notice some fuel leaking out. Use the rags to keep yourself clean. Gas is harsh and can irritate your skin. The fumes can make you nauseous too. work in a well ventilated area. After the old fuel filter is removed from the mount reverse the procedure. Place the new filter into the mount (with the arrow facing in the direction of the flow, towards the front of the truck), Install the new retaining clips that came with the filter, and install them the same way that the old one's were removed (look at them closely, they can snap in two ways but only one way is right). Slide the fuel line back onto the fuel filter (as straight as possible). sliding the fuel line back on, on an angle can damage the o-ring (do not force it back on). After both fuel lines are installed, gently tug on each fuel line. Make sure that they are secure. Reinstall the fuel pump fuse or relay and cycle the key on and off to pressurize the fuel line. Turn the ignition key off and go back to the fuel filter, check for leaks. Start the engine and again check for leaks. Clean up your work area and be careful where you store those rags. Until the gas completely evaporates, they are very flammable. Any questions, please write back.
Feb 21, 2014 | Sewing Machines
Ran straight out the box
Sounds like you ran it with the choke on - best bet is to take the carburetor apart and make sure the float isn\'t suck and clean it out. Take out the spark plug and spray it with carb cleaner and dry it - wipe out the spark plug area. Reinstall the plug and carb. Give it a pull a few times let it run then adjust the throttle to the lowest setting and then back to the desired operating speed. Listen to the engine you should be able to hear the choke cut off when you adjust the throttle.
Jan 12, 2013 | Husqvarna Sewing Machines
How do you clean brother SQ9050
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide this is important for the tension
try using a different bobbin
clean under the needle plate and in the bobbin area for lint
also possible that the machine may need some type of adjustment
or the machine could be starting to have a timing problem
Dec 08, 2012 | Brother Sewing Machines
ECHO PE- 200 won't stay running
Check and replace the impulse line if you haven't already. How did you set your carb screws after the rebuild? Start with them lightly seated and then give each a 3/4 turn out to get yourself started.
Mar 17, 2017 | Sewing Machines
I have a Singer 6105 and the thread is birdnesting for the second time in a few weeks. I have cleaned the bobbin area, threaded and rethreaded and changed needles. All to no avail. When this happened a few...
Double check:
Threaded with presser foot up.
Feed dogs are engaged.
Stitch length set at proper length.
Thread is feeding from the bobbin spool in the correct order and through the proper guides.
Problem still there - take the machine and a sample of the stitching back to the repair guy and ask him to check the timing.
When you pick up the machine, take a scrap of fabric and give the machine a thorough test run - threading, bobbin winding, stitching before leaving the shop.
Feb 05, 2010 | Singer Sewing Machines
Husky 55 chainsaw
All chainsaws are air cooled. The problem is the cylinder head often sits underneath the gas tank. People fill their tanks with a mixture of gasoline and oil and often spill it or overfill the tank causing that oily mixture to coat the cylinder often. Then all the saw dust and dirt sticks to the oil and pretty soon the cooling fins on the cylinder head and all the parts surrounding it are coated with an oily dirty grime that keeps air from circulating around the cylinder head letting it cool normally. I'm not that familiar with a Husky but you need to be careful about other parts in the area, but you need to clean off the cylinder head so that it can get some cooling and quit heating up the gas in your tank. Usually there is a vent in the gas cap also and if it's plugged it will cause the gas tank to pressure up and force more gas than is necessary into the carburetor. Either clean the vent or buy a new gas cap.
Apr 23, 2009 | Husqvarna Viking 1
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Feb 18, 2009 | Husqvarna Husky 165
General up-keep and maintenance for activia 140?
Clean, clean, clean the bobbin race area, oil the designated oiling spots (if there are any), and change the needle for each new project (or 6 hours of sewing). I'm not a Bernina user but have sold another swiss brand and in our training the need to clean and CHANGE THE NEEDLE was stressed heavily. Many users will leave the needle in place until it breaks, sewing through thick and thin, knits and wovens. And there is always going to be lint building up in the bobbin race area which will eventually "felt" up into a wad if left. Simple cleaning is lifting the needle plate, (or opening the front flap if front loading), removing the bobbin case, and brushing around the whole area carefully with a small soft bristled brush. Then oiling (with quality light machine oil), running gently for a few seconds unthreaded, then reassembling. Also wipe down the exterior of the machine with a damp cloth and clean between the tension disks by sliding a single layer of fabric into them.
Jan 27, 2009 | Bernina Activa 140
Husqvarna chainsaw repair
Usually empty fuel, use hook to pull out line , remove filter. Remove air filter cover and airfilter ,now you should be able to see line. Most just pull of carby and go through tank, some you may have to take screws out of av mounts in back of tank to see hole to put it back in.cheers hope this helps if where a stihl i could tell exactly.
Oct 29, 2008 | Husqvarna Husky 165
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
