Question about Sony Playstation 3 (PS3) Console
When I turn my ps3 on the green light comes on and I can hear my fan motor come on but it is making a weird noise and nothing is coming up on the tv then after about 30 sec. the system shuts off !! I can turn it back on and it does the same thing!! I used it the night before to watch a movie and it worked just fine ! then I moved it to a different tv and it started doing this !! any one have any ideas I could really use some help!!!! thanks in advance "Ron"
Ps3 website works wonders
Posted on Jul 31, 2013
  • 1019 Answers
SOURCE: PS3 start up problem
if the hard drives are interchangable or replaceable, i,d give that a try. Other than that it seems as if the bios-eeprom or memory chips are acting up.
I remember MS having the same problems with the 360. Overheating issues. if your consoles are warranted, get them replaced. If theres any sort of setup disk with these consoles ( as bought-demo et,c ) try starting up with that In.
Mike @ Compurepair.
Posted on Feb 22, 2008
SOURCE: ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Posted on Nov 10, 2008
  • 7 Answers
SOURCE: nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Posted on Mar 20, 2009
  • 48 Answers
SOURCE: PS3 fan speeds up really fast and loud then red blinking
Check this out:
Posted on Jun 05, 2009
SOURCE: when I turn my PS3 on the green light come on for about 2 sec
have you cheked the kabels and stuf
Posted on Sep 06, 2009
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Had the fan for a year, recently plugged it in the rotating works the fan light turns green when I push it but nothing blows out. Shouldn't there be some air coming out of the fan? If so what makes it not...
Either the fan motor went bad or the bearings are siezed so that the motor cannot start.
It is possible sometimes to get WD-40 worked into the bearings and get them going again.
If you listen closely you should hear the motor trying to start... if so then get WD-40 worked into the bearings at the top and bottom of the fan part. If there is no noise the motor is bad and the fan is junk.
Heatman101
Feb 25, 2010 | Lasko 2530 Elite WindTower Fan
The light@ fan is on but you cant get a pic on tv
make sure tha your HDMI or whatever cable it is your using is connected properly.
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
Push on button and green light comes on then goes off in 10 sec
my tv been in my storage for about two years i pull it out pluged it in and only the green light on the button comes on you can hear it make a noise like the screen is about to come on but nothing.then the green light shuts off. please if anyone know what the problem is please e mail me.
shadowbowl71
Mar 17, 2009 | RCA HD52W59 HDTV Projection Television
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Jan 05, 2009 | Sony KV-32S42 32" TV
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
RCA HD52W59 HDTV.....will not turn on, makes a weird noise
you need a new flyback. Its a very easy repair you need flyback 259296 and you can get a new replacement at the following link and they explain step by step how to replace it. Heres the link
http://servicemanuals.vstore.ca/
Sep 04, 2008 | RCA HD52W59 HDTV Projection Television
Sony Playstation 3 (PS3) Console Logo
94 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
