Question about Arris Dsr-4410 Professional Satellite Reciever
Motorola DSR 4410MD
We need help to program TV channels in our DSR4410MD,
Fast facts on DSR 4410MD
From Main Menu, arrow over to Diags and Select. First screen should display MENUS. Arrow over to it, press Select and change from whatever is displayed "Fact n" or "Diag x" to "Off", then press Select. This should turn it off.
I've run into a few that won't remember this setting and will default back to Fast Facts in approximately 2 minutes. Rebooting the receiver makes no difference. I have a call into Arris Tech Support about this and will report back if they have a solution.
UPDATE: According to Arris (aka Motorola), you'll need to get this DSR-4410MD authorized for an encrypted service (e.g., Fox, Discovery, Scripps, Disney) and the Provider can send down a remote command to turn off that function. According to Arris, there's no way for the end-user to do this. Of course if you're using this receiver's digital outputs (e.g., ASI or GbE), these Fast Facts won't appear on the video stream. These Fast Facts are strictly available thru the analog video or CVBS port.
Apr 03, 2014 | Arris Dsr-4410 Professional Satellite...
Can a motorola dsr remote be programmed to run a dish network receiver?
Hi bobcor43, my name is Mike Houston of DISH Network and I see where youwant to program a Motorola Remote to the DISH Network receiver. While theremote may connect to the DISH receiver to have full access to our receiver itwould be better to use our remote, if you want I can look at the account to seethe different options to help with setting up the remote or getting you theremote that goes with that system. My e-mail is michael.houston@dishnetwork.comand I will be able to help further with this issue.
Apr 17, 2011 | Arris DSR922
DSR 922- to begin with it wouldn't shut off, no function will work with the remote, unplugged it and replugged it and now there is nothing but the inspirational channel on G3 217. H20
IF the receiver lost its sat settings you had, you best check the internal battery. the lithium battery should be 3.70 volts...if its dead you need to replace it, without interupting the power source...this will also cause you to lose your unit ID number. then you won't be able to subcribe to programming...the 922 can be repaired if the battery dies.
Jul 09, 2009 | Arris DSR922
Cant get digital channal on my DCP 501
From page 24 of the Installation Section
The clear protective film on the DCP501 display must be removed and transferred to the inside back cover of your
DCP501 Home Theater System User Guide. The Unit Address and Serial Number found on the protective film is
required for activation of your DCP501 cable TV receiver by your cable TV service provider.
On Page 28 -
Do not disconnect the cable connection between the RF In and To RF In ports. Removal of this
cable could disrupt operation of the DCP501.
IMPORTANT! The digital cable feature of your Motorola DCP501 can be activated only in
certain cable systems throughout North America. Contact your local cable TV provider to
determine whether the digital cable feature of your Motorola DCP501 can be activated. In cable
systems where the digital cable feature cannot be activated, you may connect an external cable
receiver provided by your local cable provider. For best results, connect an external cable
receiver through the audio and video inputs on the back of your DCP501.
Page 74 -
Using DCP501 Cab le TV Functions
The DCP501 has an advanced CATV set-top terminal that allows you to view cable channels.
The DCP501 must be authorized for cable TV operation by your cable TV operator before it will
tune channels.
To use your DCP501 to view cable channels:
1 Press SOURCE to display C ATV on your TV. C A TV and the last channel tuned are displayed
on the DCP501 display.
2 Press MENU to display the TV program guide on your TV.
3 Press GUIDE to display the television program guide on your TV.
4 Change channels by pressing CHANNEL/PRESET���� or making your selection with the
If you receive an electronic message from the cable operator, the message icon �� turns on.
You must use the TV program guide to retrieve an electronic message.
Additional DCP501 cable TV functions include CATV Record and CATV Channel Scan.
If you don't have the manual go to:
http://www.retrevo.com/support/Motorola-DCP501-Receivers-manual/id/393bh936/t/2/ and register to get it. It's free.
Mar 21, 2009 | Motorola DCP-501 Receiver
I get get digital signals on dsr 922
does the creen say searching for channel? if so you might have to update the maps...go to G! 3 and leave there for about 15 to 20 minutes...make sure you got a dc light....if no you have a tuning issue...play with the skew...
Feb 16, 2009 | Arris DSR922
No picture
It has been a while since I worked on these kind of electronic equipment and I do not remember or kept any notes about specific troubleshooting. I worked for a company before that was repairing these motorola satellite receivers for starchoice Canada.
Are you using the audio/video inputs or RF input?
Where in Canada do you live?
Nov 21, 2008 | Arris DSR922
Dsr 922 no dc light on g1 etcs
you are not on the satellite. need to reporogram or fine tune these satellite into receiver.
Oct 11, 2008 | Arris DSR922
Unable to connect to Digital satellite receiver
I threw the mitsubishi VHS recorder under a bus, just like ' YOU CHANGE , CHANGE ,CHANGE FOR MY SAKE'S' grandma, and invested in a new DVD recorder, 2 yr g'tee and latest tech. GODDAM A--- well old grandma and anyone or anything else that gets in my manical lust for power. CHANGE EVERYTHING FOR ME, ME ME, ER UM US US US.
THANKS FOR YOUR TIME GUYS.
Aug 20, 2008 | Mitsubishi Televison & Video
Motorola dsr 922 satellite receiver
Sorry , I have a Motorola DSR 922 problem which has nothing todo with a phone. I was crusing around looking for online help and did not relise this was a phone only site.
Mar 07, 2008 | Motorola Mobility RAZR V3
Arris Dsr-4410 Professional Satellite Reciever Logo
Top Arris Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Arris Audio Player and Recorder Expert? Answer questions, earn points and help others
