Question about Home Security
HDD Error on covisec alcatraz ald-400lcd - Home Security
Deleting vido files from hard drive
For this you will have to transfer the particular video into ur pc.. Then you can edit the video like how ever you want. you can usw sony vegas software for this.
http://www.covisec.com/product/SHR-2042/SAMSUNG_SHR2042_4_CHANNEL_DVR_STAND_ALONE_DIGITAL_VIDEO_RECORDER_TRIPLEX_250_GB.html
this is the manual for ur product
May 29, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
I AM GETTING HDD FORMAT ERROR E:31.00 SONY DCR-SR68
I AM GETTING HDD FORMAT ERROR E:31.00 SONY DCR-SR6E. PL.SOLVE THE PROBLEM
Sep 11, 2011 | Sony Handycam DCR-SR85E HDD Camcorder
How do you rotate cells
Press the space bar, this should rotate the cell by 90 degrees per press.
Feb 26, 2011 | ValuSoft Prison Tycoon Alcatraz
Home Security Logo
47 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
