Question about Dryers
No backup lights - Dryers
    Genius:
  • 1,617 Answers
Posted on Jul 31, 2013
2001 toyota echo backup light always on after i replaced backup light switch?
Is it possible you did not get it adjusted correctly ?
Dec 14, 2012 | 2001 Toyota Echo
Backup light not working
Replace the backup light on the right side. Its most likely burned out. A blown fuse would cause both lights to not work. You might have bad wiring to that side. If you have access to a volt meter, have an assistant put your car in reverse while you check the voltage at the backup light socket. Make sure to tell your assistant to keep their foot on the brake pedal. Voltage should about 12 volts
Jul 25, 2012 | 1999 Pontiac Grand Am GT
My drivers side backup light isn't working. I changed the bulb and it still doesn't work. Apparently there isn't a fuse for the backup light. Can anyone help?
If the other one is working then there is something wrong with the wireing between the two of them, or the connection in the light or the bulb contacts are dirty in the holder.
Nov 29, 2011 | 1999 Jeep Grand Cherokee
Backup lights stopped working, replaced one complete light assembly and the fuse.
I would say that the backup light switch on the transmission is faulty, or the wiring to and from the switch. Most times if the backup lights do not work this is the root cause.
Mar 02, 2011 | 2004 Chevrolet TrailBlazer
Location of the Backup light switch.
I didn't find a location for the backup light switch,
But found the following on Autozone.com:
Backup Light Switch Operation:
00610_backup_light_switch.jpgAn open switch that prevents voltage from being applied to the backup lights until the vehicle is put in reverse. Putting the vehicle in reverse closes the contact and applies power to the rear back-up lights. Check under the dash or somewhere near the steering column if you have a column shifter. If the shifter closes or opens the backup light switch mechanically, one should be able to trace the cable and mechanisms that turn a cam that connects to the backup light switch, somehow. May have to disassemble the steering column area to see it.
Jan 27, 2011 | 1995 Lincoln Town Car
The backup lights on my 1998 Jeep Grand Cherokee won't work. Have checked all the things I know how to except the NSS. Where is the NSS located and am I better off trying to clean/adjust it or replace it?
the backup light gets its power from the neutral safety switch on transmission.
\When you put vehicle in reverse it toggles the switch in the tranny to engage the backup lights.
if that plug has the wire broke off the backup lights will not work.
Nov 14, 2010 | 1998 Jeep Grand Cherokee
Parking and backup lights quit working.everything else works including instrument lights.checked fuses and parking light relay both are good. Can someone please come up with a suggestion.
Try checking out your light bulbs in parking and backup light locations. Sometimes when one bulb goes out or just comes loose, it stops the entire circuit from operating.
May 20, 2010 | 2001 Ford Taurus
I have a 1999 pontiac grand am and the reverse lights and brake lights work but i can not get the tail lights to work. I discovered that the reverse light on the bottom of the car is missing the connector...
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Find 3 wire connector going to lense in trunk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brown wire light green wire & black blk is grd moke sure its good, lit grn back up lights,drk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brn tail lights turn parking lights on & with a test light back probe connector no power to brown? ck fuse trace harness to switch wires all good bad switch if you know how to use ohm meter you could use that to ck for shorts on continuity Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Aug 30, 2009 | 1999 Pontiac Grand Am GT
1995 Dodge Spirit 4dr sedan V6...no back up lights.
You do know your backup lights work in conjunction with safety neutral switch/backup switch on transmission right?
Jul 16, 2009 | 1995 Dodge Spirit
Backup lights not working at all
That is your problem, the backup switch, it is on the side of the transmission.
Mar 10, 2009 | 1998 Jeep Cherokee
Dryers Logo
16 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
