I have a flat screen ambilight 50" we bought in 2008 or 2009 we turn it on and right in just a few seconds it starts blinking red and will not come on.
    Top Expert:
  • Televison & ... Master
  • 36,514 Answers
The power supply has failed
Posted on Jul 31, 2013
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
The Lg lcd was srtruck by a remote and now looks like a small crak on the inside towards the bottom right hand corner and there is no picture but audio does work
Posted on Nov 09, 2008
  • 44 Answers
SOURCE: blinking red lights
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
dsacco86
  • 1077 Answers
SOURCE: red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Posted on Sep 09, 2009
SOURCE: Phillips ambilight 50 in red light problem
I had this problem on a 42" Philips Ambilight. After reading in another forum, opened up the back, and found 2 leaking capacitors on the center circuit board (main power supply pc board) toward the bottom. Tops of the capacitors were bludged out (10v 3300uF) and leaking electrolytes. Unsoldered the old ones myself, went to Radio Shack. They were out, so order 12 on ebay for $6.63 including shipping. Resoldered and works fine. Can't do it yourself? Take the board out (just unhook the cables & unscrew it ), and take it to a computer shop or tv repair or someone who knows how to solder, and have them change them. Piece of cake!
Posted on Oct 01, 2009
  • 2318 Answers
SOURCE: My 50 in philips ambilight plasma will not turn on
The failure with your plasma is with defective capacitors in the power supply.
Check the link below with info on how to DIY.
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Posted on Jul 31, 2010
My 50 in philips ambilight plasma will not turn on and blinks a red light 7 times and repeats
Jul 16, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
My TV will not turn on. Power light is blinking
my 32" panasonic lcd t.v will not turn on but the red light keeps blinking in front?
Oct 12, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
Aug 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Jul 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My 50 inch plasma
We have a 50 inch magnavox plasma screen. We found and used a fix from fixya! It only costs us $34.00 campared to the $300.00+
anyone wanted to look at it. The problem was on the powerboard but was two little capacitators with the model #3300 10v. We carefully took the back off the tv and removed the power board, went to a local electric supply store and bought the 2 parts for $2 each, we then found someone (tv repair shop!) to sauter the new ones on! Got it home put it back together and it stayed on, no depressing shutdown after a few seconds! you can find a picture of a fried capacitator on yahoo images, they are supposed to be flat but if defective will be bubbled at the top or even split! I am calling Magnavox today to complain that they are not recalling this part that should have been a better quality capacitator! Hope this helps some people!!
May 23, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Plasma will not turn on
Sounds like u might have a bad power supply
Apr 05, 2008 | Televison & Video
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
