Question about Refrigerators
KBRS22KGWH00 Model kitchen aid fridge. Used a gasket # 12550115Q and it is not fitting properly. Can someone please advise if I was sold the wrong part?
    Top Expert:
  • Refrigerators Master
  • 12,223 Answers
Go to www.repairclinic.com and see the part o.k
God bless you
Posted on Jul 31, 2013
the dr
  • 447 Answers
SOURCE: Kitchen Aid Fridge
freezer too???
Posted on Oct 03, 2007
  • 1314 Answers
SOURCE: Kitchen Aid Fridge problem
ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
Posted on Jul 13, 2008
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
mgprice
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
Refrigerator motherboard How can I tell if the motherboard of my kitchen Aid refrigerator went bad
Make sure your fridge doesn't have a recall for evaporator as is the case on my fridge I also thought it was electronic and first tech thought it was a leak in reality the evaporator was clogging and causing freon to not keep fridge cold or freezer to work properly but kitchen aid won't let you know you will have to let a tech look that info up for you.
Mar 15, 2014 | KitchenAid Refrigerators
Tip
Important Info need when asking a question about your Major Appliance
Please get the model From your appliance before you post your question. We can not do a thing for you with out that model. Thanks you so much. We are trying to help you.
on Mar 15, 2015 | Electrolux 78956 Frigidaire GE Maytag Jenn...
It is obvious that there is a major design problem with this model in that numerous enquiries under Kitchen Aid's "popular solutions" deal with a multitude of self-cleaning issues. We have had to...
NEVER use the self cleaning mode.
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 25, 2011 | KitchenAid KESA907PSS Electric Kitchen...
Hello, I purchased a Kitchen Aid Architect II series KUDSO3FTPA3 ~ two years ago. It is deigned so you can put your own panel on it. Duw to a design issue with my cabinets I was not able to add my own...
There is a MUCH better way! go to www.applianceart.com, these guys have tons of panel options including stainless and fax stainless that was featured on HGTV and the Today Show. www.applianceart.com (Appliance Art)
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Nov 23, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
