Avid error code -2034 for mac - Televison & Video
How can i find a activation code for a cracked pro tools 9 on mac computer
You can search Google and find Crack Codes, although
let me tell you threw experience, You will have problems, conflicts, and system crashes.... it's Not worth it, I started buying inexpensive interfaces that come with a verified version of protools
hope this info helps ?
Feb 27, 2015 | Avid Pro Tools 9 Crossgrade LE for PC, Mac
Tip
Mac Sony HDR-SR11 MTS to Avid converter-Convert AVHCD to Avid I have Sony...
I have Sony HDR-SR11 AVCHD HDD camera to shoot family videos and beach videos. However, after I transfer .mts files from Sony HDR-SR11, Avid does not support the AVCHD file. I wonder the best AVCHD workflow into Avid from Sony HDR-SR11 and google for solutions.
I was recommended with Sorenson Squeeze to convert Sony HDR-SR11 MTS to Avid DNxHD codec. However, Sorenson Squeeze does not natively support .mts and the file extension should be changed to .m2ts. The conversion time is much longer than that the original clip. One thing should be mentioned is that the exported DNxHD is loaded quickly to Avid. Sorenson Squeeze also costs quite a lot. I just find a better Mac Sony HDR-SR11 MTS to Avid converter - Aunsoft MTS/M2TS Converter for Mac. The price is dramatically low comparing to Sorenson Squeeze, and the output MOV video works in Avid MC and Xpress Pro.
Here is how I import Sony HDR-SR11 camera videos to Avid Media Composer by converting 1920x1080 MTS to HD MOV.
Step 1. Load Sony HDR-SR11 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR11 MTS to Avid converter on Mac Snow Leopard, and click the "Add" button to load HD .mts videos.
Step 2. Choose AVC MOV for Avid.
Click the "Format" option, and choose Adobe Premiere/Sony Vegas > MOV (AVC)(*.mov), and the Sony MTS to Avid converter will transcode the HD MTS files to MOV for Avid MC, Xpress Pro.
Step 3. Convert Sony HDR-SR11 AVCHD to Avid.
Click the convert button under the preview window, and the Sony MTS to Avid Converter will start converting HDR-SR11 AVCHD MTS to HD MOV for Avid Xpress Pro, or the upgraded Media Composer 5.
As soon as the conversion in finished, you can import Sony HDR-SR11 videos to Avid Media Composer, Avid Xpress Pro for editing. The output HD MOV also works in Final Cut Pro and iMovie, and other non-linear editing software like Adobe Premiere on Mac OS X.
If you are using other Sony AVCHD cameras, you may also face the same problem. Have a look at the Sony HD camcorder page for Sony HDR-XR520, HDR-CX110, DSC-TX7, HDR-TG7 and other models.
on Jul 26, 2010 | Cameras
Install avid 4.3
Avid 4.3 for Mac is a PowerPC application and will not run on Intel-based Macs:
Avid 4 3 upgrade Avid Community
Mar 21, 2014 | Apple MacBook Pro Laptop Computer with...
AVID LIQUID 7.2 NOT IMPORT AVCHD FILE PLEASE HELP ME
Reasons why we cannot usually make AVCHD MTS recordings accepted by NELs:
But what you want is more than that. Even some of you enjoy reviewing the raw videos, still most of users want to edit their bunch of video clips and then create their own short movie for future refresh. So some powerful NELs may come to as a solution. FCP, Adobe Premiere, Sony Vegas, Avid Media Composer, all those are good to use and easy to handle. But some of users may find that the raw videos came from their camera may not successfully imported into these NELs. Why? Because the unfriendly format of your video can't be supported by NLEs.
How to solve the AVCHD(*MTS) can't import Avid Media Composer this problem?
First , you need a powerful AVCHD Converter for Mac to help you convert your files into other normal format. The Avid Media Composer support AVI, MOV,MP4 ,etc. But you may worry about the poor quality after the conversion. Don't worry , this powerful converter can trans-code into normal formats and at the same time without any quality drop.
Mar 17, 2014 | Pinnacle Studio MovieBox DV 9 (210100349)...
DAE error -1115
You haven't stated your problem, aside from the error code. Please include the hardware setup, computer and Pro Tools version and plugins you are using. Also include your experience with the setup; was it working at some point? etc.
I run PC and Mac versions of this system, and I have had to go as far as to enter the computer CMOS setup to sort out problems. Pro Tools issues can be caused by many aspects of your hardware and software setup.
I know it can be tedious and time consuming, but have you tried to access the Avid (Digidesign) site's Q & A locations? You may have to do this if the solution to your problem is not immediately apparent.
Most of all, if you are not running properly registered software, with a user account on Avid, you are asking for problems here. Cracked versions of the program and plugins can cause unresolve-able problems.
Try these Pro Tools related sites to see if they offer some help.
http://duc.digidesign.com/showthread.php?t=165488 RE: error code 1115
http://duc.digidesign.com/showthread.php?t=189857
http://www.sweetwater.com/forums/showthread.php?10723-Pro-Tools-headache..help-please
http://homerecording.com/bbs/showthread.php?t=288891
http://www.osd-uk.com/protoolsformedia/index.php/problem/tl-space-crashing-my-pro-tools-8-rig/
Oct 27, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
What is error code 43 for AMC 5 on a mac?
Mac Error Code 43 occurs due to wrong OS Configuration or due to wrong installation. To Fix Mac Error Code 43, just read the easy steps are given below:
Easy Steps to Fix Mac Error Code 43
Step 1: Reset PRAM Settings
    ·First shut down your Mac computer.
    ·Meanwhile Mac is shutting down you need to prepare for pressing command+option+P+R keys all together.
    ·Now turn on your Mac and press command+option+P+R command before the screen with grey start-up appear.
    ·At this point of time hold all these keys until you hear a start-up sound for three times and then release all the keys. Step 2: Delete All Locked Files
    ·You need to navigate to Applications then open utilities and click on terminal.
    ·Now open the terminal and type chflags -R nouchg command on it.
    ·Now find at the bottom dock and double click on the Trash icon.
    ·Press command+A to select all the files in the trash folder.
    ·However, in case of you not able to find the terminal window, arrange finder window, so that you can see at least a part of terminal window.
    ·If you have done then press Return key on the terminal and empty the trash folder.
    After following these steps if you are unable to Fix Mac Error Code 43, then just dial our toll free Mac Technical Support Number 1-833-493-0111 and get instant help.
1 833 493 0111 How to Fix Mac Error Code 43 on Mac OS
Aug 19, 2010 | Avid Media Composer 3 Upgrade Version for...
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
Aug 26, 2009 | Avid Xpress Pro 4.8.1 Full Version for PC,...
Techincal solution
Do you mean .omf and .mxf? On mac the souce files are quicktime. Audio, generally works with .aff the best but can use .wav also. Though that message seems to suggest it is an audio card problem. I'd check if you can record in other sofware programmes and maybe if you have an on board sound card as well as an external one (if using PC) turn the on-board on off in MSDos as it could be conflicting.
Mar 31, 2009 | Avid Xpress DV 3.5 (0500-03677-01) for PC,...
OS X 10.4.10 Stuck Loop
H MerryAnn
I run Avid on my mac and have not experienced what you describe. Avid uses a lot of memory. The first thing I'd look at is do you have enough memory to run the OS and Avid. If that is OK check your screen res' (the system normally warns you if that is incorrect) If you have the install software try uninstalling and re-install to see if that helps.
It does not sound like a OS problem.
Regards
Paul
Aug 18, 2008 | Apple Mac OS X 10.4
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
