Question about Gateway FPD 1730 17 in. Flat Panel LCD Monitor
Gateway co,\mputer goes into power saving mode how do you keep it from going to that mode?
  • 23 Answers
SOURCE: My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Posted on Jan 24, 2009
  • 41 Answers
SOURCE: When I turn boot up my gt5220 the monitor briefly
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Posted on Dec 02, 2009
Endeir
  • 140 Answers
SOURCE: why does my gateway computer go into power save
Because it is set default to auto power saver moder after a certain amount of time and you can adjust these settings in the control panel power settings.
Hope this helps ^^. Please dont forget to rate, Thanks
Posted on Mar 02, 2010
leitusdotcom
  • 172 Answers
SOURCE: my monitor on my gateway
Hi, if the monitor stays on "saving mode" it means you have some bad capacitors inside the monitor, so you have to get it fixed. If you connect another monitor and you still get the same thing, it means the display's resolution is out of range. So restart safe mode and reconfigure it. I hope this helps.
Posted on Apr 26, 2010
buda2832
  • 59 Answers
SOURCE: Gateway desktop enters power save mode while in use.
boot and adjust the power settings for all "when on A/C" to never. to take it out of power save press any key on the keyboard or press the power button (but dont hold it down)
Posted on Jul 08, 2012
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Computer Gateway SX2802-07 PC Desktop keeps entering power save mode
could be power mode is not set correctly. could be clock/battery is low and causing early saver mode? is your pc time/date correct?
is your ac adapter working properly or is it going bad?
Aug 24, 2012 | Gateway SX2802-07 PC Desktop
Have a gateway computer and it is in power save mode cannot get it out of
Have you recently installed any updates? Have you installed any hardware? Have you tried unplugging it and hitting F8 to go into safe mode to restore it?
Jan 23, 2012 | Computers & Internet
How do I get out of auto power saver
If your computer system goes into auto power saving mode you can get out of this state by clicking the mouse, moving the mouse, pressing enter or space. Try the wake up button if you have one on your keyboard.
You can set the setting of power saving mode by navigating to your Windows control panel and double clicking Power Options.
Under the power schemes tab select the time period to go into standby mode. Click apply and ok, when you are finished.
Take care!
damnor01
Jun 30, 2011 | Gateway GT5692 Desktop Computer
MY COMPUTER KEEPS RETURNING TO POWER SAVE MODE, DOES THIS MEAN THAT THE BATTERY NEEDS REPLACING
No, the battery is fine.
Click Start
Click Control Panel
Click Power Options
Change the number of minutes before it enters power-saving mode.
Click OK
Dec 24, 2010 | Gateway 506GR PC Desktop
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
My monitor on my gateway mid tower goes straight to power saving mode so I can"t log on
Apr 26, 2010 | Gateway GT4016 Desktop PC
My problem is the same, it happens when i'm in fullscreen.
go in and fix the power settings under screen saver disable sleep mode on drives and monitor disable sleep mode on every thing just use blank screen instead
bes fix 4 ya
Jul 29, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Logo
19 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
