Question about Mitsubishi WS-65807 65" Rear Projection Television
My 65inch Mitsubishi started humming through the volume now the picture gets snowy
    Top Expert:
  • Mitsubishi Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Jul 31, 2013
Snowy picture
Check its Ariel cable for firmness. Check the orientation of antenna.
If all are correct, check and replace its tuner. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 07, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
My 65inch Mitsubishi tv started humming and buzzing with the volume now picture is getting snowy at time
follow this steps and fix it. God bless you
Jul 31, 2013 | Mitsubishi WS-65807 65" Rear Projection...
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link www.fixya.com/users/bugoy31
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
My 65inch mitsubishi tv has sound but no picture what going on?
There is a video reset switch infront of the set, try to reset it.
Feb 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Snowy picture
Usually a snowy picture means that you have a bad ground connection. You should see that some channels are beter than others. Verify that the cable connection is good. Try a different cable if you can. If that has no effect, than we need to start looking at the tuner itself. If you can change channels but just have a poor picture, chances are that a resolder of the tuner section will resolve the problem.
Keep us posted.
Dan
Jul 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV intermittently goes snowy.
time for a new tuner probably about 150-200 bucks to fix
Jun 13, 2006 | Mitsubishi PD-4001 40" TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
