Question about Sony Playstation 3 (PS3) Console
My ps3 keeps turning back off without anything coming up on the tv !! I plug it in and the red light comes on and I push the button and the green light comes on but nothing comes up n the tv and within a min or so it goes back off !! then I can push the button again and the re light comes back on then push it again to green but dontget nothing on the screen and then it shuts back down again in a min, or so !!
praky16
  • 744 Answers
SOURCE: Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Posted on Jul 20, 2009
Sutibun
  • 186 Answers
SOURCE: my playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Posted on Jan 23, 2010
SOURCE: when I turn it on, the light turns green but shuts
This is the Yellow Light Of Death, or YLOD. Mine has happened 3 times.
Basically, the solder on the heat sync has cracked. It can be re-flowed i.e. melted again, but it doesn't always work.
Posted on Mar 02, 2010
  • 28 Answers
SOURCE: I turn on my ps3 and the green light comes on for
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Posted on Mar 16, 2010
SOURCE: my ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Posted on Jul 20, 2010
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Menu will not show up
Yes you can!
TRY THIS cmfin and trey!
Shut the system off in the back then un-plug and re-plug all cords.
Turn the power on in the back.
The ps3 should have a red light on in the front.
Push and HOLD the power button in front!
It will go through a red light to green beep at you then go back to red.
This should HARD reset it.
If you have ever changed tvs or played on a different tv the ps3 will sync itself to that tv.
SO a regular tv is different then my hdtv so it would need to be reset to play on a different tv!
I hope it helps!
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
Wont show up on TV
You have to reset the console by holding down the power button on the console itself until the light changes from red to green and back to red again, after that make sure you have the composite cables ( red white and yellow ) plugged into their correct slots . Then check to make sure the tv is on the video channel. And lastly , this is the part that got me, make sure the cable that plugs into the back of the ps3 is in there securely, it shouldnt be loose or anything. Thats what fixed it for me.
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
