Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
Jazzy 1113 ATS- Speed/profile light blinks, chair no go. Batters OK
2 Suggested Answers
  • 692 Answers
SOURCE: Have a jazzy 1113. The speed profile lights flash
The flash of the speed lights indicate that you are in the charger inhibit mode and if the charger is not plugged in then you have a problem that needs to be checked by a tech or your provider that sold you your chair Sorry I don't have a quick fix
Posted on Sep 26, 2010
Jazzy chair 600 3 red lights 4 yellow 1 green no power both batteries read 12.5
Have the joystick controller tested. Make sure the cable is fully seated in the chair connector.
Feb 17, 2014 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113
check wiring and pcb in your chair...it may be loose connection in between the path
Sep 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
All the lights are blinking on the speed display.. we've had the chair plugged into both the back of the chair and the armrest.. the chair still won't move.
The speed display will flash whenever you have the charger plugged in. Either in the back or in the joystick. Hopefully you didn't have them both plugged in at the same time. If after you unplug the charger you still get the flashing speed lights then you have an inhibit problem with the chair. The inhibit function will keep you from being able to drive the chair while charging. This repair is beyond anything you can do and must be referred to a Pride dealer or Repair service Hope this helps you
Apr 22, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Replaced batterys in jazzy chair speed indicator keeps blinking - no code for it - plug in charger works for a minute after unplugged but then goes back to blinking?
Jazzy is in lock mode try the following to unlock:
Lock Mode
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple side to side.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked
Hope this helps
Mar 29, 2011 | Pride Jazzy 1113 ATS Indoor Power...
JAZZY 1113 AFTER CHARGING 10 HOURS SHOWS ALL LIGHTS, THEN AFTER AN HOUR OF USE IT SHOWS 1 RED BLINKING. BATTERIES ARE ABOUT 1 YEAR, IT READS 26 VOLTS AT THE PINS ON CONTROLLER. ANY SUGGESTIONS?
Mary yep Even though the batteries are charging they are not holding the charge to provide enough power for the chair. Usually you have one battery that is weak and causing the problem but both batteries must be replaced. If Medicare paid for your chair then they will pay for 80% of the new batteries. You can contact the provider that sold you your chair and ask if they can replace your batteries. If not, you can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have tech come out and repair the chair for you and they will bill Medicare for the cost of repair. Hope this helps
Feb 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Have a jazzy 1113. The speed profile lights flash then the chair shuts off. The batteries show full.
Sep 25, 2010 | Pride Jazzy 1113 ATS Indoor Power...
My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
We have a Jazzy 1113 Power Chair. The chair is fully charged, but does not move. What might be the problem?
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Dec 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
55 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
