Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Craftsman ys4500 tractor will crank but not turnover. changed battery and plugs. starter good...sprayed starter fluid in spark plug holes and engine fired blue smoke and then stalled out.
wadembly
  • 489 Answers
SOURCE: Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Posted on Jun 08, 2009
huffman49
  • 235 Answers
SOURCE: ys4500 Lawn Tractor will not start.
did you hit something while mowing if that is the case then check the flywheel key. even if it only has a small nick in it that would keep the engine from starting up...good l uck
Posted on Apr 11, 2010
wireguy212
  • 1627 Answers
SOURCE: starter get hot engine won't start
You likely need to get the valves adjusted,it sounds like the decompressor is not working.You need to get the compression down to 130 lbs while cranking or the starter can't overcome the compression.Try turning the motor past the compression stroke by hand and see if it will crank faster,if so then the decompressor is out of adjustment.If the decompressor is not just a lob on the valves then you need to call the repair depot for craftsman and find out what you need to do to fix the problem.If none of the above works then you may need a battery,or just clean the cables and battery posts.
Posted on Apr 19, 2010
philwalker78
  • 608 Answers
SOURCE: I HAVE A 2005 CRAFTSMAN LT1000 LAWN TRACTOR THAT
It sounds like the carby is flooding badly. Check that the float needle in the carby is sealing properly. You need to remove the float bowl on the bottom of the carby and hold the float up with your finger and check that the fuel stops flowing out when you do this. Regards Phil
Posted on Apr 14, 2011
roadtech7
  • 297 Answers
SOURCE: where is the spark plug located on my craftsman lawn tractor model 917.273360
James, it is at the front of the engine. It is next to the 4" by6" metal cover that says OHV. It is on the right hand side ( sitting on the tractor), There is a black wire the size of a pencil ( diameter ), hooked to it. It is set deep in the engines cylinder head. There is a rubber boot over the end of the spark plug. Remove the rubber boot, you will hace to grip it hard and pull it off. Then you will be able to remove it, using a deep 5/8" socket with a 4 to 6 inch extension.
Hope this helps, if you need more let me know.
Matt
Posted on Dec 02, 2011
I have a craftsman rear engine riding mower 30"
This battery charged? When was last time valves adjusted. If out adjusted the compression not release
Oct 19, 2014 | Garden
Craftsman ys4500
pull the fuel hose and check for fuel flow to the carby
check all safety micro swiitches
Mar 31, 2017 | Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
I have a 3 year old ys4500, wont start
Have you tried bypassing the cut off switch, by joining the wires together
Sep 20, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman YS4500 won't turn over
low battery charge or the teeth on the starter gear is bad. the fly wheel should turn if the starter is engaging. i have disconnected the seat switch and it still turns over. the blade and parking brake switch will not let it do anything if disconnected. to change the starter gear only takes a few minutes after the covers are removed.
Apr 24, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Ys4500 Lawn Tractor will not start.
Apr 11, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Jun 07, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Have new proper batt.Have new starter celenoid,new
Remove spark plug and attempt to crank. If it turns faster (without compression) it may be valve adjustment. If it still turns over slowly with plug out check battery ground for tightness to mower body. If the ground is good check the starter by removing battery and atttaching jumper cables to pos and neg battery terminals first, then the pos jumper to starter terminal (where red wire attaches). Then touch the neg jumper to a good engine ground (I use shroud bolt). Be careful as this last connection will cause some arcing. If it still cranks slowly with the plug out, it is probably the starter.
Apr 11, 2009 | Craftsman Garden
CRaftsman riding mower's engine turns over just fine, won't crank
Take the spark plugs out and squirt a little oil into the cylinders and replace plugs. If you have spark then spray some starting fluid into the air intake and have at it . You should here a noise and that should be the engine firing up. I hope this helps. donnyb60
Mar 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
