Question about Magic Chef CTB1722 Top Freezer Refrigerator
Freezer not keeping temp. hear a click from bottom
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
How come my refrigerator keeps beeping the temp keeps going up
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 16, 2011 | Samsung RB2155SH Bottom Freezer...
For the last couple of weeks I have been hearing clicking noises from my fridge. The freezer temp keeps increasing slowly climbling upwards to the 20's then it would come down to negative #'s. Now it is...
You will need to check the relay switch to the compressor as the contacts can be worn out.
Also the thermostat must be checked, the auto defrost timer must also be looked into to see if the timer works to shut down.
The clicks can be the relay clicking but not connecting or cutting off when the current is not good enough due to poor contacts.
Nov 02, 2010 | GE Profile Stainless Bottom-Freezer...
MY FRIDGE FREEZER KEEPS TRIPPING OFF AND COOLING DOWN
Replace the overload/relay . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . This is if you are hearing an occasional " click " . It is easily replaceable .
If you do not hear a "click" , tap on the thermostat ( knob that adjusts the temp ) , and see if the freezer fan comes on . If so , then replace the thermostat .
Nov 08, 2009 | Refrigerators
Bottom Refer not staying up to temp
the fan has probably went totally out you get to it by taking the back panel inside your freezer out
Dec 28, 2008 | GE GTS22KBM Top Freezer Refrigerator
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
Apr 24, 2008 | Amana ABB1921DE Bottom Freezer...
Magic Chef CTB1722 Top Freezer Refrigerator Logo
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
