Question about Fossil CE1000 Watch
Ce1008 need a replacement pin for the watch band
2 Suggested Answers
SOURCE: i need to replace a fossil watch band
call foleys or dillards and ask for the number to the company
and thy can assist you
Posted on Jan 06, 2008
When can I find a pin for my watch band?
If you can't find a pin just get a safety pin and cut out with pliers the length of pin Ben slightly and insert, should be fine for a while
Feb 13, 2015 | Watches
Pin missing from ce1008 watch band
that is sad , it may sound daffed but it worked for me many times if you get a sawing needle and cut it down to size then super glue it in, or a paper clip will do as-well save you $150
Feb 07, 2013 | Fossil CE1008 Watch
Trying to change leather watch band. This watch has a narrow space to attach rather than a wide space. Have tried to push pins and they will not move.
The easiest way to insert and remove watch band pins is with a band tool. This small tool has a very small, thin fork on one side, usually made of tempered or hardened steel, that you use to spear one end of the watch pin; you can then quickly and easily apply the leverage needed to pull one end out of its mounting hole. Many watch pins have a small collar at each end designed to catch this forked end. These inexpensive tools are sold at most jewelry supply houses or come as part of a "watch maintenance kit" that can be purchased online or at Harbor Freight. However, you can also solve your problem without this tool.
There are two approaches to removing stubborn band pins without the right wrench. First, you can use a sharp knife blade (a screwdriver blade won't work) to try to grab the end of one of the pin to try to pull it out of its mounting hole. Band pins without collars are usually designed to pull a bit more easily from one side than from the other; if you're not having any success on one side of a pin, try the other. In addition, you might want to wear leather gloves--using this procedure, it's almost certain that the knife blade will slip out of control at least once or twice, and there's a serious risk of accidentally cutting yourself unless your hands are protected. Further, you may gouge a notch in your knife blade, damaging its smooth edge. Still, if you need to preserve the band pins, this is a common way to go. Finally, if you put too much pressure on the mounting hole in a plastic watch case, you run the risk of tearing out the hole. In that case, the watch is now useless as a wristwatch, because you can't attach a new band to it.
On the other hand, if your replacement watch band comes with replacement pins, you don't need the watch pins that are currently mounted in your watch. If that's the case, use a pair of nipper pliers to cut the pin in half. You can either push the old band out of the way, or you can even cut it off to get better access to the pins. If you cut the pin approximately in the center, it should be easy to pull each half out. Conversely, if you cut the pin very close to one edge, you may have a bit of a challenge pulling the short end out--but it's still quite do-able.
I always change out the band pins when I change a wristwatch band, so I have become increasingly fond of cutting the old pins in half and pulling them out if I can't easily get them out with a band tool. Doing so minimizes the risk that I will damage the pin mounting holes in the case. Even in a metal case, elongated mounting holes will not hold a pin as securely, making it easier for the band to spring out and the watch to fall and get damaged.
May 17, 2011 | Timex Expedition Watch Midsize with Fast...
How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
    mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
    Jul 21, 2010 | Seiko SGF204 Wrist Watch
    Pins keep popping out when watch band gets snagged. What size are the pins for watch band?
    mcdevito75 here, These pins may be a bit worn in the band of your watch, if so, you"d have to order a kit with various size pins for replacement. BEST BET, look for a small watch repair shop to fit new pins in the band.
    Jul 12, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
    Replacing watch band on pathfinder pas410. can't get pins out to replace band.
    Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
    Rate me, plz.
    Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
    I need to change my watch band
    Where the band meets the watch - push the band a bit to expose the pins that hold it on.. The pins are spring loaded and will compress with the push from a tiny flat screw driver..
    You can get replacement bands at most retal stores..
    OR - take the watch to WalMart jewlrey dept and find a band that fits and they will help you chang it..
    Good luck ;o)
    Sep 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    My invicta stainless steel band has two bent pins and I was told to send back to invicta repair. Is the repair of watch band more expensive than a new watch band and who can put on new band.
    Most watch pins go for an average of 5 to 10 dollars per pin. If the band is in good condition there is no need to replace it. Most invicta metal bands can retail from 35 dollars and up. We are located in the Holyoke Mall in Holyoke MA
    Apr 08, 2009 | Invicta Speedway 9223 Wrist Watch
    Watch band
    I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
    Tools:
    1 push pin like you use on bulletin boards with a plastic head
    1 small hammer like a tack hammer
    1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
    1 small block of wood
    Try to pick a well lit table in a room where you will not be interrupted.
    Procedure:
    1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
    2. Carefully line up the push pin point with the top of the pin.
    3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
    4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
    5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
    6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
    Dec 25, 2007 | Fossil AM 3688 Wrist Watch
    Fossil CE1000 Watch Logo
    56 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
