Question about Bosch 0261210147 Crank Position Sensor
The "Check engine "light on my 1996 Sonoma 4.3 enine comes on. I used OBD2 to diagnose. It indicated the "Cank position sensor (Bank 1) code 0340. I renewed the sensor but the light comes on after driving a short distance. Please help!!!
  • 43 Answers
Hi fault code P0340 in your Sonoma means that:http://dtcsearch.com/P0340/
P0340 - GMTypePowertrain - Ignition System or Misfire - ISO/SAE ControlledDescriptionCMP Sensor Circuit Conditions
CauseEngine cranking for 2 seconds, then the PCM did not detect a CMP sensor pulse, condition met for 2 seconds
or you can ask the 24 hrs live technical support http://www.diyobd2.fr, they will like to help you, good luck
Posted on Sep 05, 2013
My 1996 nissan truck cuts out in warm weather and has a troubleshooting code P0340
code p 0340 refers to camshaft position sensor ((CMP) sensor A bank 1---circuit malfunction====causes --wiring---CMP sensor---ECM
check the wiring and harness connections
change the CMP sensor
Oct 18, 2017 | Nissan Cars & Trucks
1996 Dodge Neon Code P0340 152000 miles the car died on the interstate at 60 mph & while coasting to the side it started back up & this is the code I had at the parts store. When it started up the...
code p 0340 refers to cam shaft (CMP)sensor A bank 1---circuit malfunction===causes --wiring---CMP sensor ---ECM
indications are faulty harness connections , faulty wiring (stopping the starting indications ) and lastly replace the sensor
Oct 31, 2017 | 1995 Dodge Neon
Cheking engine light is coming code p0330
this obd2 trouble code table can help you understand the meaning of code, for this code, you can try:
Check the resistance of the knock sensor on bank 2 (compare it to factory specs)
Check for broken/frayed wires leading to the sensor
Replace the knock sensor on bank 2
Sep 07, 2011 | 1996 Toyota Tacoma
I have a Chevy 2006 Aveo. Two codes came up when the engine check light was put on a scanner. Code P0340 and Code P0133. The check engine light has turned off and on by itself several times in the...
P0340 OBD-II Trouble Code - Camshaft Position Sensor Circuit Malfunction
This indicates that a problem was detected in the camshaft position sensor circuit. Since it says circuit, that means the problem could lie in any part of the circuit - the sensor itself, the wiring, or the PCM. Don't just replace the CPS (camshaft position sensor) and think that will definitely fix it.
Symptoms can include:
* Hard starting or no start
* Rough running / misfiring
* Loss of engine power
Causes: A code P0340 could mean one or more of the following has happened:
* a wire or connector in the circuit could be grounded/shorted/broken
* the camshaft position sensor may have failed
* the PCM may have failed
* there exists an open circuit
* the crankshaft position sensor may have failed
Possible Solutions: With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
* Visually inspect all the wiring and connectors in the circuit
* Check for continuity in the circuit wiring
* Check the operation (voltage) of the camshaft position sensor
* Replace the camshaft position sensor as required
* Check the crankshaft position circuit as well
* Replace circuit wiring and/or connectors as required
* Diagnose/replace the PCM as required
P0133 OBD-II Trouble Code - Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
This involves the front oxygen sensor on Bank 1. This code indicates the engine air fuel ratio is not being adjusted by the oxygen sensor signal or the ECM as expected to do so, or not adjusted as often as expected to do so once the engine is warmed or under normal engine use.
Symptoms: You will likely not notice any drivability problems, although there may be symptoms.
Causes: A code P0133 may mean that one or more of the following has happened:
* The oxygen sensor is faulty
* The wiring to the sensor is broken / frayed
* There is an exhaust leak
Possible Solutions: The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is more than likely the front Bank 1 oxygen sensor. You will likely wind up replacing it but you should also consider these possible solutions:
* Check and fix any exhaust leaks
* Check for wiring problems (shorted, frayed wires)
* Check the frequency and amplitude of the oxygen sensor (advanced)
* Check for a deteriorating / contaminated oxygen sensor, replace if necessary
* Check for inlet air leaks
* Check the MAF sensor for proper operation
Hope this helps (remember to rate this answer).
Feb 09, 2011 | 1999 Chevrolet K1500
Replaced the O2 sensor unit and the ECM(programs installed) but I'm still getting CHECK ENGINE LIGHT(P0001). what is the possible problem and how can this be resolved?
P0001 Fuel Volume Regulator Control Circuit/Open The above code is about an oxygen sensor code for the heater circuit located in bank 1 sensor 1. (bank 1 is at exhaust manifold by the #1 cylinder head, bank 2 is on the 2nd cylinder head. On some engines, both exhaust manifolds could have one oxygen sensor each side and the 2nd cylinder head will have the sensor 2). On the oxygen sensor itself, it has 4 wires which are color coded. Two of wires are for the heater circuit that heats the oxygen sensor to make it reach optimum operation quickly. Those 2 oxygen sensor heater wires could be shorted between the sensor and the ecm (engine computer) or other engine components.
oxygen%20sensor%20heater%20copy.jpgThe common fix for this code is to check the integrity of the heater wires. Check the wires for insulation and routing which could be loose or touching a hot exhaust that can short the wires. If the engine has too many miles, it is possible that the heater circuit inside is worn and shorted which needs a replacement of the oxygen sensor. If you have a DVOM, you can also test the continuity of the heater wires from the oxygen sensor to your computer pins.
More detailed fixes will be provided as soon as you give the symptoms of the obd2 trouble code. ATS will provide the wiring diagram so you can trace the color coded wires. Use an obd2 code reader or scanner so you can access this obd2 trouble code. When you have this obd2 code list, use it as a reference and give the code to ATS. We will then send you all the possible fixes for the obd2 trouble code. ATS has lots of fixes for obd2 gm codes, obd2 ford codes, dodge obd2 codes and all obd2 import codes such as Toyota obd2 codes, Honda obd2 codes, Nissan obd2 codes, etc. All fixes for this obd2 codes are guaranteed or your money back.
Important TIPS about Oxygen sensor:
The oxygen sensor content of the exhaust gas indicates when the engine mixture is operating lean or rich. When the oxygen sensor detects that the engine is operating rich, the signal voltage is high, and any decreases in the signal voltage means the engine running is lean. The engine computer supplies a reference voltage like one volt or five volts, and then shows the change in the sensor return voltage as the sensor's resistance is changing. If you have connected everything properly, when you crank the engine, you should see the check engine light coming out.
Unheated oxygen sensors rely on the heat of the exhaust gases to reach the working temperature, therefore they might start to cool down while the engine is idling and revert back to a default air-fuel ratio setting. This type of sensor usually has a single wire connector, though others have two. Unlike the fuel pump relay, the 02 sensor heater circuits have a separate fuse for each sensor and grounds, which are controlled by the engine computer.
To read a voltage across the heater, one side must be connected to (+) and one side must be connected to (-), which is accomplished by the computer or a transistor. It can read 12V between each wire and a separate ground if it was connected to positive and the other was not yet connected to ground connection (for details, please contact ATS).after you replace oxygen sensor you have to drive for so many miles before it resets its sef
Dec 13, 2010 | 2001 Volkswagen Beetle
Ml350 replaced a/b cam position sensor reset computer & and erra codes p0016/p0016 check engine ligth is reset car drives with light off when engine is turn off and started the light goes out if you...
P0010....'A' Camshaft Position Actuator Circuit (Bank 1)
P0011....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012....'A' Camshaft Position - Timing Over-Retarded (Bank 1)
P0013....'B' Camshaft Position - Actuator Circuit (Bank 1)
P0014....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015....'B' Camshaft Position -Timing Over-Retarded (Bank 1)
P0020....'A' Camshaft Position Actuator Circuit (Bank 2)
P0021....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022....'A' Camshaft Position - Timing Over-Retarded (Bank 2)
P0023....'B' Camshaft Position - Actuator Circuit (Bank 2)
P0024....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025....'B' Camshaft Position - Timing Over-Retarded (Bank 2)
I think your sensors are pattern parts and the readings /resistances are not the same as the original parts ,try some bosch units is my first suggestion ,
Nov 02, 2010 | Mercedes-Benz ML350 Cars & Trucks
Check engine light on computer codes 171 174 171-HEGO sensor unable of snitch cylinder bank #1 fuel system at adaptive limit (1990 on) code 174 hego sensor snitching too slow, cylinder bank #1 (1990)
switch, we run off snitches. 171 174 banks 1 & 2 Lean. Most likely cause are Upper Intake Manifold Gaskets, failed seals. It's not 1990 on. It's 1996 and on OBD2.
Aug 03, 2009 | 2003 Ford Explorer Sport
1998 GMC Sonoma threw code P1133 02S 1/1
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
I would have the repair shop see if they either damaged or left disconnected the oxygen sensor for engine cylinder bank one upstream sensor, this sensor would have been disconnected if the oil pan was removed.
Apr 20, 2009 | 1998 GMC Sonoma
Bosch 0261210147 Crank Position Sensor Logo
73 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
