Question about Toshiba Televison & Video
Screen on toshiba 50HP66 is black with no audio
    Top Expert:
  • Toshiba Master
  • 12,223 Answers
Reset the TV.follow this steps and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Jul 31, 2013
I have a 50inch Toshiba 50hp66 520watts and when I turn it on its a black screen And flashes
Take it to the nearest authorized Toshiba repair centre,
since there is nothing that you can fix, by yourself.
May 19, 2014 | Computers & Internet
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Red dots show up on the black portion of the screen. Any ideas? Thanks, Steve
I had the same red dots in the dark areas and it was driving me nuts. I also have a toshiba 50hp66. Luckily I found out that it's an easy fix. Open up the back of your tv and on the left side you will see two adjustment pots labelled Vsc and Vy. I first marked with a sharpie where the factory defaults were. Then I adjusted down (to the left) the Vy a little and the red spots were gone! My TV looks like new. Hope this helps.
Aug 08, 2010 | Toshiba 50HP66 50 in. Plasma Television
No picture
try replaced DIGITAL PCB ***'Y
Manufacturer Toshiba
Part Number 72784100
Description DIGITAL PCB ***'Y
Apr 27, 2010 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 went black after pop/crack sound
most units are made by someone else. your unit probably has LG parts. get the unit looked at by a Toshiba authorized servicer. they may be able to repair it at component level. the $900 you stated sounds at least $200 too high for board level repair.
Jun 19, 2009 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
My Toshiba 50HP66
It sounds like you have a fault on the picture frame board and for a competant technician this is not much of a problem. Or it could be something as simple as dry solder joints. Either way the tv can be saved and is worth fixing. Hope this helps.
Oct 07, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Jul 16, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Televison & Video Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
