Question about Miele T7744C Dryer
When drying the laundry,(Miele T7744C) water does not get into the properly closed condenser unit at the top anymore but is accumulating on bottom of the dryer, I hear it sloshing under the drum. Also some leakage on left front on floor. I had some fluff accumulating and cleaned the condenser unit below etc. All clean. Can pipe from condenser unit below to plastic condenser unit in top be blocked? If so, where is it? Thank you.
    Top Expert:
  • Miele Master
  • 12,223 Answers
Test this steps and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jul 31, 2013
dniro592006
  • 121 Answers
SOURCE: Miele dryer leaks water.
sounds like a washing machine problem
its not spinning clothes dry
Posted on Jun 09, 2009
  • 15 Answers
SOURCE: Miele T355 timer doesn't latch
Modern dryers use a step motor on the timer, as opposed to a fixed rate timer seen in older models. The timer advances using one of two different mechanisms, depending on the model. On most, the timer receives a signal from the thermostat that a predetermined temperature has been reached - on others it receives the signal from the moisture sensor (if so equipped).
Posted on Jul 20, 2009
  • 70 Answers
SOURCE: We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
Posted on Mar 30, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Hello - I have a
1...You may have more than one problem on your problem with your dryer not heating.
2...Your noise (ba-ba-dum) is being made by your drum rollers that probably have flat spots on them and is in need of being changed.
I will include two solutions to your two problems, I am not sure if the disassembly of the dryer that I am going to send if for will be applicable to your dryer disassembly but it may help
-----------------------------------------------------------------------------------------------------------------------------------------------Problem 1...Not heating
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Problem 2...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Dec 29, 2010
  • 70 Answers
SOURCE: Miele T250c dryer, has power but the start light
Hi Most likely reason for start light not illuminating is the door lock part number 5712492
Posted on Feb 01, 2011
Why would the Dryer not heat after an international move from Austrailia 230V 50 hz to Thailand 220V 50 Hz, when programs, air movement, evrything else functions properly?
Your problem is one electric leg has no power. You are getting power for a single need. But you need double that power for the heating need.
like 110. And. 110. Equals 220 Soo 110 is supplying one need ,that needs only 110 But the heating coils need 220 that is where the second leg comes in... Be sure bothe breakers have powers going out. Into dryer
Apr 29, 2014 | Dryers
Water not draining to container,leaking.
Undu the hose or pipe at highest level and make sure it is not clogged
Aug 08, 2017 | Miele Dryers
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
Miele WT945 leaks water from internal drain
Hi
If it is the bottom hose on the condenser box leaking.
This is a vent.
It is most likely the condenser box is blocked with fluff and will require cleaning or replacement. I imagine the appliance is not drying very well if at all
Apr 02, 2010 | Miele WT945 Front Load Washer / Dryer
Mar 23, 2010 | Miele Novotronic T220 Electric Dryer
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Miele T358C dryer. water not being pumped out of the sump??
TRY THIS:
TRY THIS:
In some cases cleaning the condenser out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, it is normal for there to be some water in the tubes when you do this, you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier for air circulation; and empty the water container often or reconfigure your pluming arangement to reduce the water left in the container. The circuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later :?) DRRXR
TIP OF THE DAY--
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 02, 2009 | Miele Novotronic T220 Electric Dryer
UPRIGHT FREEZER
Some units have a selector switch that says; reduce moisture/save energy. If you have this its obvious what to do. If you don't have one or are getting condensation anyway, check the door gasket. Make sure its getting a proper seal. The outside air has water in, aka, humidity. If the unit sucks air from outside, as it cools it will condense and make dropletts accumulate on the top. The drainage from the defrost may also be seeping in and cause the water too. Especially if its on the bottom. It may have a clogged drain line.
Mar 05, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Drying cycle - laundry comes out wet!
possibly that drain pump is not pumping out - washer dryers take in water during the dry cycle. check filter
Mar 17, 2007 | Bosch Classixx WVF 240S Front Load Washer...
Miele T7744C Dryer Logo
357 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
