Question about Casablanca Fan Versa Touch2 W-72 Remote Control
We've had this fan for several years and it worked fine until yesterday we used the Reverse Button and now it won't go back to normal operation when we operate the low - medium - high buitton. Is it possible it is because of low battery and if so, how do I replace the battery? Please reply by E-mail My e-mail address is leofourn@videotron.ca
  • Leo Fournier Jul 31, 2013
    changed the batteries, clean the corrosion at the battery contacts, synchonzed the xmtr to the recv on the fan and now everything is working fine. Thanks for the tip.
    Top Expert:
  • Casablanca Fan Master
  • 12,223 Answers
Replace batteries and clean the contacts and try again. Otherwise you must open the r.control cleant the keypads for dirty, corrosion, oxide with contacts cleaner. and try again.
if the problem pesist you have a SYSCOM faulty.
God bless you
Posted on Jul 31, 2013
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
For some reason the heater does not generate heat. the fan works but no heat. Any Ideas?
I've got an easy way for you to check, and then we can help you from there.
First pop open both lids to your furnace (this may require a screwdriver). Turn up your thermostat, push the safety interlock button in if it has one (it's a button that turns off the power when the doors are removed), and watch.
On most modern furnaces (past 20-25 years) you'll hear/see:
1. Inducer fan
2. orange glow (ignitor)
3. Gas valve opening and ignition (flames)
4. Main Fan.
that's normal heater operation.
The most common issue here is a burned out ignitor, in which case you wouldn't see the orange glow but the sequence would attempt to continue anyway (the gas valve will open and hiss gas, but it won't lite, then it'll give up and try again a few minutes later).
On older furnaces there's a pilot light to start with, the click of the gas valve and boom... ignition.
On new furnaces it's
Inducer fan
gas valve opening
spark - ignition
Main fan.
and there are some oddballs in between, particularly the Lennox Pulse. If that's your furnace just back away slowly and call a professional... some guys won't even touch those, so be sure to mention what it is... if you call a pro.
So go ahead and watch it run, then tell me/us what you see.
May 06, 2011 | Bionaire Heating & Cooling
I have a 1998 Saturn SL2 DOHC with ~140,000 miles. The car runs great, but I am having trouble with the coolant temperature. When first starting the car up in the morning, the coolant temperature gauge...
When you said you replaced everything, did that include the temperature sending unit?
The temperature sensor just operates the cooling fan or fans for the radiator.
The temperature sending unit operates the temperature gauge in the dashboard. If that thing is faulty, the gauge won't work right.
If you did change the sending unit, it could be possible that the computor is screwing it up, but in my 41 years as a mechanic I never heard of it, when a computor goes, nothing works.
Aug 13, 2010 | 1998 Saturn SL
Casablanca Ceiling Fan
I've never heard of the light and reverse buttons being reversed. Normally It's the fan and light thats swapped (but your aware of that already). I would try a working w-32 from one of the other fans. There's also a shop called Fan Man Lighting in Minnesota who has a guy named Jason who has been fixing fans for over 20 years, He helped me with my Casa problems. Their website is www.FanManLighting.com Hope this helps.
Nov 01, 2008 | Casablanca Fan 3245T Ceiling
Hampton bay altura 68
Read this on another thread - apparently the solution came from HB's tech support.
Turn the fan speed to HI and then select Reverse.  You should hear a "click" and see the fan reverse direction.  It seems that the reversing relay only works when the fan speed is set to HI.
Good Luck!!
Two Metre Man
Jul 12, 2008 | Hampton Bay 24002 Ceiling Fan
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Casablanca Fan Versa Touch2 W-72 Remote Control Logo
177 people viewed this question
Top Casablanca Fan Televison & Video Experts
Steve
michael vanier
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
