Question about KWorld UB445-U2 USB-TV Tunner - ATSC/8VSB Intput, Clear QAM, High Defi
UB445-U2 tv signal select no video appears, how I check hardware set up ?
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    We have a TV Digimate Type DGL2700 model LT27C2M1 We did'nt see the channel Just a blue screem. Can you help us?
    Check if the antenna or the cable is properly connected at the back panel. Check also if the TV is set to audio video system or to tv channel .The two must be set properly to receive tv signal.
    Nov 08, 2010 | Digimate DGL2700 27 in. LCD Television
    Hook up and programming
    have you try to check the the video cable connections from the dvd to the tv..?
    Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
    I live in Pretoria South Africa using Windows 7 I have installed the drivers for DVB S 100 however I cannot find signal scanning with Media center and my Theater please help
    Follow this steps and try
    in windows 7
    On the start screen, scroll to Tasks, click settings, click TV, and then click Set Up TV Signal.
    Follow the steps to connect a TV signal, depending on the type of tuner or tuners that the cable is connected to
    else try
    The Windows Media Center TV Pack has an "Auto Select" option which removes channels that have a weak signal from the EPG. To run the "Auto Select" option to check the list of available channels and to evaluate the signal strength for each channel, follow these steps:
    1. Start Windows Media Center.
    2. In the Start window, scroll to Tasks, click Settings, and then click TV.
    3. Click Guide.
    4. Click Edit Channels.
    5. Click Auto Select.
    The "Auto Select" option tests each channel. Based on whether a strong or a weak signal is found, the "Auto Select" option puts a check mark in the box next to the channel. As soon as the detection process is complete, you have to click the "Save" option to save the newly selected channels to the EPG.
    esle if the problem still persists
    have a look aon the microsofts support in the following link
    http://support.microsoft.com/kb/955485/en-us
    Feb 19, 2010 | KWorld DVB-S 100 (DVBS100) Video Capture
    THE VGA PORT DOESNT SEEM TO BE ACKNOWLEDGING THE COMPUTER OR VICE VERSA. ACTUALLY, IT DOES RECOGNIZE IT BUT THERE ARE NO DRIVERS FOR IT , ANYONE KNOW WHERE TO GET THEM
    You need to give more information about your set-up for help. What type of computer are you using and what operating system.What type of graphics card. All of these systems have to be compatible with the television input for you to get operation. I found this in the appendix of the owners manual on PROSCAN website. www.oncorpus.com. The customer service telephone for PROSCAN is 1-888-977-6722 The PC Screen continually appears and disappears.
    Check the connection between the TV and the computer and see if the connector is locked.
    􀁺 A “There is no signal “message appears.
    This happens if the signal from the video card is exceeded for the maximum resolution or frequency of the TV. Try to set the
    maximum resolution or frequency for the TV.
    See if power save mode of the PC functions properly.(This is deactivated when any key is pressed or the mouse is moved)
    􀁺 The screen looks like there is water flowing on it.
    Check the connector connected to the TV.
    􀁺 The screen is unclear and blurry.
    Change the frequency and phase adjustment. Change the Resolution and frequency to the standard limit.
    􀁺 Unstable and flickering screen.
    The resolution and frequency of the PC's Graphics Card should be set within the TV's range. Check the TV menu’s current
    mode and standard mode and set it up again.
    􀁺 Some modes in standard mode are not working.
    Check the compatibility of the video card.
    If it is not working for compatible hardware, try to upgrade the driver of the graphics card
    May 09, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
    Get ''not supported ''message on vx-1018-ah
    Verify this is a Pioneer VSX-1018AH.
    The manual explains it all... The problem is probably an incompatible setting on your source.
    Search for "not support" in the manual...
    http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
    I think this may do it... From Page 86...
    No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
    If they are not, please connect them using the component or composite video jacks.
    • Depending on the connected source component, it’s possible that it will not work with this receiver
    (even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
    between source and receiver.
    • If the problem still persists when connecting your HDMI component directly to your monitor,
    please consult the component or monitor manual or contact the manufacturer for support.
    • If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
    or other setting for your component.
    If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
    • While analog video signals are being output over HDMI, use a separate connection for audio
    output.
    • When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
    THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
    audio connection.
    • To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
    receiver to a component or TV with the DeepColor feature.
    Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
    No image is output when an
    input is selected.
    • Check the video connections of the source component (see page 18).
    For high-definition video (using component video connections), or when digital video conversion
    is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
    using the same type of video cable as you used to connect your video component.
    • Make sure the input assignment is correct for components connected using component or HDMI
    cables (see The Input Setup menu on page 67).
    • Check the video output settings of the source component.
    • Check that the video input you selected on your TV is correct.
    Some components (such as video game units) have resolutions that may not be converted. If
    adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
    resolution settings on your component or display doesn’t work, try switching Digital Video
    Conversion (in Setting the Video options on page 72) OFF
    Apr 05, 2009 | Pioneer Audio Players & Recorders
    Get closed captions on some channels, but not all, even though it is CC
    RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
    Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
    If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
    If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
    easyab
    Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
    KWorld UB445-U2 USB-TV Tunner - ATSC/8VSB Intput, Clear QAM, High Defi Logo
    41 people viewed this question
    Top KWorld Televison & Video Experts
    kenwal
    Level 1 Expert
    Ruben Balisbis
    Ruben Balisbis
    Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
