Question about Sony CDP-CE215 5-Disc CD Changer
Carousel keeps spinning. Won't stop. - Sony CDP-CE215 5-Disc CD Changer
If anybody can help me please I need to know how to repair the carousel before the CD changer he does not spin thank you
Most of the carousels are driven by a small motor through a gear train, but some are belt driven. You would have to look underneath the carousel to determine what the mechanism is. If it's belt driven, make sure the belt isn't slipping. With the changer unplugged, find the carousel motor, then gently turn it by hand (make sure you are turning it in the correct direction) to check for excess friction, broken gears, jamming by a foreign object, or slipping. If you hit a hard stop while turning the motor DO NOT FORCE IT. Investigate the stop; it's probably your problem. Some changers rotate the motor in one direction to turn the carousel and in the other direction to clamp the CD in the spindle mechanism. If the spindle clamp is hung up, this will prevent the carousel from turning.
Jun 16, 2015 | Audio Players & Recorders
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
When I changed cds, the carosel starting turning and won't stop or respond to any other commands. I turned off, and then back on and it just keeps turning.
It sounds like it's a position sensor issue, either the player is not detecting the cd's in the carousel or it's not detecting which position it's in. Try looking for a sensor and cleaning it with some isopropyl alcohol and a Q-Tip.
Nov 28, 2012 | Sony CDP-CE375 5-Disc CD Changer
Hi, my husband bought me your KAMENSTEIN WORLD OF MOTION SERIES ANIMATED HORSE CAROUSEL many years ago. I did not keep the box or manual and now I want to ask can you e-Mail me a download or one I can...
I cannot loacte an actual manual but....The Kamenstein Carousel teapot was part of the MKI versions of teapots Kamenstein released in the mid-2000s. The teapots came in a range of colors, from blue to red, and they had a small carousel on the top. As the water boils the carousel spins around, bringing an element of whimsy to your tea time. The teapots are all metal and can be used on any type of stove top.
Instructions
    • 1 Fill the Kamenstein Carousel teapot with water just below the sprout.
    • 2 Place the Kamenstein Carousel teapot on the stove and set the heat to "Medium."
    • 3 Allow the water to come to a boil and remove the Kamenstein Carousel teapot from the stove.
    • 4 Pour the hot water into a cup over a tea bag.
Read more: How to Use a Kamenstein Carousel Teapot ' eHow.com http://www.ehow.com/how_7718254_use-kamenstein-carousel-teapot.html#ixzz1JAQxUJn2
Thanks
Apr 10, 2011 | Vacuums
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a...
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Oct 07, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rock-ola 498 Carousel Spins Continuously
Look on Ebay for manuals or try at www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Sep 02, 2009 | Wurlitzer Jukebox 1015 One More Time...
Sometimes stop advancing. sometimes keep advancing 5 to 8 slides.
the mechanism needs cleaning. it is an almost purely mechanical device and needs greasing. the old grease gets hot and dusty and starts to get sticky. when this happens, the moving parts tend not to move. the mechanism needs to come out for a cleaning and regreasing.
Jul 11, 2009 | Kodak Carousel 4600 Slide Projector
Cd carrousel keeps spinning
This problem is likely caused by either an open fuse or a failed Carousel Index Lamp. The index lamp is located behind the black metal cover on the right front side of the carousel - fits over the teeth. The lamp should be visible under the cover or if you peer sideways from the left front edge of the carousel. Spares are available from us.
This can also be a fuse related problem - if the bubble tubes AND the colour cylinder motors are all dead then first check for open +/-30VDC fuses in the amplifier.
More tech info on my website:
http://flippers.com/wurlitzr.html
John :-#)#
www.flippers.com
Mar 18, 2009 | Wurlitzer Jukebox CD Player
Cd wheel spining non stop
ITS NOT THE WHEEL SPINNING ITS THE LASER ITS TRYING TO READ THE DISC THAT CAUSE IT TO SPIN FAST AND SLOW FAST AND SLOW YOUR LASER NEEDS A CLEAN
Jun 27, 2008 | Wurlitzer Jukebox 1015 One More Time...
Sony CDP-CE215 5-Disc CD Changer Logo
138 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
