Question about Garden
It wants o turn off when press the gas on it takes a long time to turn on
  • 1,807 Answers
Check carb settings, check fuel line for air leaks and possibly clean and service carb.
Posted on Jul 31, 2013
Will start but not run. Bought last year only used about 3 or 4 times. Lost Wal Mart reciept.
If gasoline sits for a long time, it begins to turn to varnish. This might take only 6-12 months.
The varnish will clog up the small passages and jets in the carburetor.
You probably have new gas in the tank now, and the engine starts off of the new gas that you deliver by pressing the start button several times, but after that the gas needs to get through all those tiny passages. It won't. It needs cleaned out.
Mar 09, 2015 | Garden
I disconnected my battery in 08 tundra and now it wont idle
disconecting batt resets the computer. now it needs to learn how to set everything to run again. disconnect batt for atleast 60 seconds, re atach, start car it will start and die(dont press gas) do this over and over until it idles (could take up to 10 times). by pressing the gas you make the computer think it is idling to high so it keeps turning down the idle. it will idle fine after reseting computer and starting several times without hitting gas peddle.
Mar 09, 2013 | 2000 Toyota Tundra
Oil light wont reset
I believe on those you have to turn the key to the on postion and press the gas pedel three times within 5 sec. then turn the key off. just do it a bunch of times cause it takes a little while to get it just right
Sep 15, 2011 | 1993 Cadillac Fleetwood
How to remove "oil change" code on 04 gmc sierra
Turn the key on,and press the gas pedal three times slow,within five seconds
Jun 08, 2010 | 2004 GMC Sierra
Whirring noise every time the gas pedal is pressed
check the level of the power steering fluid,check belt tension & condition
Sep 23, 2009 | 2003 Mitsubishi Galant
I want to know how to reset the oil change reminder. I got the oil changed yesterday afternoon.
most of the newer chevrolet vehicle's the light is reset by turning on the key and pressing the gas peddle three times.
Sep 03, 2009 | 2006 Chevrolet Equinox
Igniter only glows on permanent press cycle and not timed cycles
I unplugged the ignitor and put the leads from my multi meter into the plug to monitor the signal to the ingnitor. I got 120 volts only when I turned the timer switch counter clockwise or to the permanent press cycle. When I turned the switch clockwise or to the timed cycle I wouldn't get the voltage to the ignitor. While in the timed cycle, I turned the switch counter clockwise and as I started counter clockwise pressure on the switch knob I got 120 volts to the ignitor. There is a little play in the switch and when taking up the play in the counter clockwise direction the switch would engize the ignitor. The timer switch is bad.
Feb 05, 2009 | Hotpoint NVL333GY Gas Dryer
Starting the car-- takes longer
you have a fuel problem either the filter or the pump is failing
Mar 23, 2017 | 2007 Hyundai Tucson Limited
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Oil light
Hi lady d tilli,
Take off the fuse cover on the drivers side of the dash. there should be a bunch of fuses. in the middle is a red button that says "reset." turn your key to the on position, but DO NOT START. press the reset button until the change oil light blinks, then turn the key back off it should be fine after that. for the 05's theres somthing you have to do with the gas pedal. i think you do the same, by turning the key on but not starting...and then tapping the gas pedal 3 times.
Hope this helps a bit,
Good luck,
Eitan.
Jun 09, 2008 | 2004 Pontiac Grand Am
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
