Have a lg tv, mod #21fj4rb,came in for repairs.found HOT shorted out,replaced it & HV started to come out at top of FBT ,replaced it & then tv starts up for about four seconds &then shuts down.cheeks where made & found that the screen resistor&diode were blown,also found a transistor&30 volt zener diode& ABL diode defective,replace all components & still tv shuts down, i'm at my wits as to know what is the problem?can anyone help?thanking you in advance! vic
3 Suggested Answers
  • 86 Answers
SOURCE: Toshiba model#: 32a33, chassis: TAC0303. STRG5624A
go to the nte website and download their quickcross. go to it will also do that. both of them are free.
Posted on Nov 10, 2009
SOURCE: tv does not power up
I have seen the schematic, d982 is a 13v 1/2w zener
Posted on Jun 03, 2010
I have a LG CRT TV This tv tly back HOLDER HV cable sparking its very big spark - bulb HV cable connector ...not showing picture .show spark lighting ... how can fix this? what parts of trouble ?
Replace the FBT. Never switch on this set, any more; till it has been replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to get gathered related posts.
Sep 29, 2015 | LG Televison & Video
Hot over heats
add more fans they sell those on ebay 4 pack that runs off ac outlet suck that hot air out faster
Jan 19, 2008 | LG RU-27FB30C TV
FBT partnumber help
Try to download the service manual to this set by internet. It has all details.
May 26, 2013 | Televison & Video
I have a 32" GE regular crt TV. Everything was fine and when I woke up the next day it would not turn on. Keeps making a clicking sound every few seconds like a solenoid trying to close..
Sounds like a probable shorted Horizontal Output Transistor (hot) Hopefully thats all. Sometimes the flyback will fail as well. If your not familiar with electronics I would recommend a tv shop repair. If its just the HOT transistor average repairs are 75-110 depending on your location.
Oct 17, 2010 | GE 32GT740 32" TV
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Jun 06, 2010 | RCA 35V432T 35" TV
Picture is blurred were i am seeing multiple images in odd bright colors. when tv is on without cable box, there are a couple red and green lines across the top third of the screen
Your TV has a Convergence submenu. Verify that this menu is still present (use your user manual to locate it in the menu). If it is not there, you have a solder quality problem on your HV/Deflection board and a fuse has opened as a result. It will need to be repaired. I suggest NOT using the TV until this is fixed, as further damage can result.
If you are a DiY person: remove the HV board (left side with red anode coming from FBT), clean solder from the FBT connections, reflow the connections (make them look wet and shiny), check the fuses to the right of the FBT (there are 3, they look like little rust colored boxes), replace as needed. These fuses can be hard to get, the culprit is >500mA if memory serves me. Also, give a good inspection on the rest of the board for broken solder joints and repair as needed.
Mar 14, 2010 | RCA D52W23 52" HDTV CRT TV
Focus wire from flyback transformer lost position?
Yes, yoke plug in should be next to or behind FBT.
Dec 22, 2008 | KLH 13" TV
Won't turn on
Although the other response is in much better technical lingo, it sounds to me like the television had a high voltage arc which I have seen on quite a few of the sony big screens lately. Usually, it causes a part on the circuit board, (one of many that were listed on prev. solver's list) to fail. This causes a delimma for the repairman, because when they find the bad part and replace it, sometimes it will pop again causing repeat failure of boards and/or parts on the board. Sony is known for having bad tubes on their projection sets, and it can be a difficult repair even for a trained tech. I suggest calling a sony service center in your area, and get an accurate estimate before deciding if replacing the set is the best idea. Hope this is helpful input, Russmann.
Nov 15, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
