Seiki lc-32b56 tv will not power on at all. It just stopped working. No red light, no nothing.
  • 29 Answers
Turn the wall switch back on...if it still won't work, check the breakers on the side of your house.
Posted on Jul 31, 2013
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 14 Answers
SOURCE: sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Posted on Jul 25, 2008
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
  • 1779 Answers
SOURCE: tvstopped working, green power light comes on, red light flashing
Most likely it has a power supply module problem. Have it looked at by a qualified service company.
Posted on Dec 08, 2009
SOURCE: Hyundai Lcd/Tv wont turn on (Lc-23y18)
my television is the same and has been like it for almost 18mths, still to find a cure
Posted on Mar 12, 2010
No picture and no sound but got a little red light at come on tv
Hi Cindy,
The power supply needs to be checked and repaired in your set. Please consult some local Tech.
Good luck
Jun 30, 2015 | Seiki Lc-32b56 32 LCD HDTV
My seiki tv lc-32b56 not work no power??
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 29, 2015 | Seiki Televison & Video
Volume don't work to tv
In the menu for audio, there will be a selection for TV speakers on or off. They are probably switched off.
Dec 07, 2014 | Seiki Lc-32b56 32 LCD HDTV
I can only get a blue light and it will not stay on. What is the problem?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Seiki Lc-32b56 32 LCD HDTV
My seiki tv turns on but no picture freezes at logo
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Sep 01, 2014 | Seiki Lc-32b56 32 LCD HDTV
Need remote codes for sky with Seiki tv
028,022,025. Try these codes.For more information check this link.Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Dec 09, 2013 | Seiki Lc-32b56 32 LCD HDTV
Seiki lc-32b56 will not power on
Bad power supply is usually the cause of this anomaly. Check the PS board for blown fuse, burnt resistors, bulging capacitors.
Jan 31, 2012 | Televison & Video
Need verizon remote control tv code for Seiki 32B56 TV
0205 code worked for me. 32'' Seiki TV with Verizon Fios remote.
Jan 16, 2011 | Televison & Video
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
Electro Med Services...
