Question about Poulan Pro Chain Saw 38cc, 16in. Bar, Model PP3816AV
Picture sketch when press the gas it wants to turn off or go dead sometimes
  • Poulan Master
  • 1,807 Answers
'Bogging down' Incorrect fuel air mix, fuel starvation or air leak.
Posted on Jul 31, 2013
Emachines hard drive
I'll give you a link below to a copy of your user's manual.Once it loads and opens,hit the Download for free tab and you can save a pdf copy so that you have it.
I checked,on pg 61 it says it's a standard IDE Hdd,mounted into a bracket.I'd think that you'll just need to swap out the dead one,make sure you put the bracket on right.Upside down sometimes hurts.
There are sketches of how it comes out and all,it shouldn't be a major problem.
It also has the Sys. Restore steps right after that section,ir's all in the book.
http://www.manualowl.com/m/eMachines/M5116/Manual/119640
eMachines M5116 eMachines 5000 Series Notebook User Guide
Apr 03, 2014 | eMachines Computers & Internet
Tip
How to turn your photo into cartoon
If you have Photoshop, you can also use it to turn photo into cartoon effect in your Windows 10/8/7 or Mac (macOS High Sierra included). The photo-to-cartoon effect in Photoshop is a popular effect and surprisingly easy to achieve. Here in this tutorial, you can learn to turn photos to cartoons using an assortment of filters and simple brushwork.
Step 1. Open Photoshop and add your photo into the program. Press Cmd/Ctrl+J to duplicate the background layer, then Cmd/Ctrl+ Shift+U to remove color. Press Cmd/Ctrl+J again, and then Cmd/Ctrl+I to invert the tones. Change the Blend Mode to Color Dodge. Go to Filter>Blur>Gaussian Blur. Set Radius to 8px and Click OK.
Step 2. Press Cmd/Ctrl+Shift+Alt+E to merge a new layer, then Cmd/Ctrl+J to copy it. Set the Blend Mode to Multiply, then copy the layer three times to make the lines stronger. Highlight the top layer, Shift+click the layer above the background and hit Cmd/Ctrl+E to merge. Rename the layer Sketch.
Step 3. Make a new layer, drag it below the sketch layer, then go to Edit>Fill Layer. Set Use to White and click OK. Next highlight the sketch layer and click the Add Layer Mask icon in the Layers Panel. Grab the Brush tool and set color to black, then paint to tidy up the skin, clothes and hair.
Step 4. Change the Blend Mode of the sketch layer to Multiply, then make a new layer and drag it below. Grab the Brush tool and choose a color for the skin, then begin painting. Make more new layers and paint different colors for the hair, eyes, mouth and jeans.
Step 5. Duplicate the background layer. Drag it to below the sketch layer. Go to Filter>Brush Strokes>Ink Outlines. Leave the default settings and hit OK. Alt-click the Add Layer Mask icon to add a mask that hides the layer, then paint with white to reveal the tattoos. Next highlight the white layer.
Step 6. Go to Filter>Textures>Grain. Set Grain Type: Vertical, Intensity 100, Contrast 0. Go to Filter>Blur>Gaussian Blur. Set Radius 4px. Go to Filter>Distort>Polar Coordinates and pick Rectangular to Polar. Hit Cmd/Ctrl+U, check Colorize, set Hue 211. Paint white over any lines that show through.
If you think it is difficult for you to turn photo into cartoon with Photoshop. You can also find other way in the detailed article.
Photo to Carton How to Turn Photo into Cartoon Easily and Effectively
on May 08, 2018 | Adobe Photoshop CS2 for PC
What is sketching?
Artists often sketch out their thoughts for a painting before actually painting it. Sketch sets have paper, pencils, colors and other items such as pastels, and charcoal that one would need for sketching purposes. A sketch is the first step you need to do before you start painting.
Feb 03, 2013 | Crafts & Hobbies
When i press the gas its not proforming right sometimes go dead when put gas into car
Check the voltage on the altanater, air filter, and check for vacuum leaks. Hope this helps.
Jan 31, 2012 | 1997 Pontiac Bonneville
2000 buick regal....The car seems like its either missing or loosing power when making a hard right turn and pressing gas. when i get off the gas its fine. It sometimes does this when driving straight, but...
A motoe mount would not let it loose power. It would however make the motor shake causing the eddect of it missing. Check the main motor mount that attaches the motor to the frame that is in front on the car just above the radiator. It has a large rubber bushing that sometimes goes bad on this vehicles. I have included a picture of what it would look like.
Dec 06, 2010 | 1999 Buick Regal
Need gas line sketch for craftsman brush wacker 32.cc
Most 2 cycle engines are basically the same. The primer button has two lines coming from it. Gas is actually s.ucked thru the carb and not pushed thru when you prime it. Take a look at the sketch I provided and hopefully you will get yours running again.58fe8f0.jpg
Apr 26, 2010 | Craftsman 25cc Gas Line Trimmer
My RCA52W59 wont turn on. I plug it in and the
Common faults with this model are flyback trans former and power supply problems (capacitors)
This set is in shut down or protection mode and will attempt to restart 3 times
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Sep 30, 2009 | RCA HD52W59 HDTV Projection Television
My IPOD screen is scrambled
This is actually common in LCD's. Either you have dead pixels which requires a new screen or a connection problem which is unlikely. That usually happens while installing a screen. If it worked once, it is probably dead pixels. A screen is medium difficulty to replace but not if you have no idea what you are doing. Good luck.
Aug 20, 2008 | Apple iPod MA446LL/A MP3 Player
Poulan Pro Chain Saw 38cc, 16in. Bar, Model PP3816AV Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
