Question about Measuring Tools & Sensors
Greenfield ride on broken steering rod - Measuring Tools & Sensors
  • 29 Answers
Try a Stanley instead.
Posted on Jul 31, 2013
Looking for Greenfield Fastcut 32 Ride on lawnmower replacement Steering wheel no.GT 2380 The plastic housing which connects to steering column has totally given up. Where can I get one?
sort of the boss kit like on cars holding it to the spline or shaft
ebay
see if the steering wheel of a newer green field model fits
wanted ads online
a rider mower workshop may be wrecking a unit
Apr 12, 2017 | Cars & Trucks
What causes the front wheels to spread out making turning and steering impossible on a husqvarna lawn tractor.
the tie rod between the two wheels has broken or come off
the steering rod works on that rod or on one wheel which is connected to the other wheel by that tie rod.
Sep 04, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Why does steering slip turning left?
broken teeth on the steering gear (attached to the steering rod) or the steering plate (the one that turns the wheels) follow the steering rod from the steering wheel down to the frame, if it goes THRU the frame look underneath the lawnmower and youll see which one is messed up, just replace the one that has the broken/worn down teeth, hope this helps
Jun 02, 2015 | John Deere Garden
Steering on a greenfield sit-on
adjust it why ??? they normally aren't adjustable
Jun 17, 2014 | Garden
Greenfield ride on mower front axle/wheels
zYou are correct. there is an adjustment for the wheels. The front wheels are connected to the steering by tie rods, as in a car. This kind of adjustment is not found in a user manual, but you can do it. Inspect how the wheels are connected and inspect the tie rods. The tie rods have to be disconnected from the wheel and turned in or out depending on which direction the wheel needs to go ,in or out. One tie rod is right hand thread. The other is left hand thread. So the adjustment is making the tie rods shorter or longer. If you do a search on the web ' riding mower tie rod adjustment', you'll find plenty of info.
Good luck
May 04, 2014 | Garden
Greenfield 28" ride on lawn tractor manual
greenfield have a facebook site, they will email you a pdf manual, good luck
Dec 08, 2013 | Greenfield Industries Disston #752980 Mm...
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
Measuring Tools & Sensors Logo
56 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
