Question about Toys
Caterpillar 257B2 parking brake keeps coming on by itself
2 Suggested Answers
alicantecoli
  • 22156 Answers
SOURCE: MY PARKING BRAKE COMES ON BY ITSELF ANF THE
disconnect it then rewire it manually via a two way toggle switch .fault is in the ECU ,most likely the manufacture has been priced out to outside contractor ,whos having the circuit boards assembled in china
Posted on Oct 20, 2009
How do I get my gogo elite traveler plus hd to engage the brake when parked on an incline?
Hi Scott, the brake itself could be failing or the other issue could be the controller itself or simply a bad connection (hopefully), so check the connections from the brake to the controller
Regards
Rob
www.gewizrepairs.co.uk
Jul 29, 2014 | Pride Health & Beauty
I have a th 360B Starts fine all hydraulics work,
Check to see if there is a switch that isolates the drive system if the foot brakes are applied. Check that solenoid to engage the torque converter clutch is operational
Oct 16, 2013 | Cars & Trucks
Oct 20, 2009 | 2005 Lincoln LS
I am looking for a wiring diagram for a 2004 Isuzu Rodeo. The fuse keeps blowing every time the brakes are applied, meaning I have no brake lights, emergency flashers or turn signals. recently my son, who...
there could be a problem with the linkage itself, when it does not come out of park there is a reason, when you force it, that is when you create bad problems for yourself. it could be something as simple as the brake lamp switch located directly on the brake pedal arm.
Jul 03, 2009 | 2004 Isuzu Rodeo
2000 ford expedition emergancy brake keeps not working. I get it fixed and a couple of weeks later it isn't working again. Mechanic says t has something to do with the cable keeps coming out of it's track....
I checked for a TSB and there isn't one for this issue. I have not heard of it either. If it were mine, I just wouldn't use it. Which cable? Ay park brake or under body?
Item Part Number Description 1 2780 Parking brake control 2 2783 Remote release lever 3 2A635 Parking brake rear cable and conduit — (RH) 4 2A635 Parking brake rear cable and conduit — (LH) 5 2A602 Parking brake cable equalizer 6 2853 Front parking brake cable and conduit
Jun 24, 2009 | 2000 Ford Expedition
Brake on off switch
Two posibilities that i can come up with, either you have a short in a wire for your brake lamps, or (this one more likely than the other) you have a bad brake lamp switch, that is located on the brake pedal assembly itself, should be a little black cylinder with a spring loaded shaft at the end, sometimes these get hungup or broken.
May 05, 2009 | 2002 Ford F250 Super Duty SuperCab
2005 silverado brake lights wont come on
get a test light, on the brake pedal itself is a two or four wire switch, check for power at the switch on one terminal, when you depress brake pedal voltage should transfer to a second terminal thus feeding power to the rear brake lights. check this and keep me posted.
Dec 19, 2008 | 2005 Chevrolet Silverado
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
