Question about Kenmore Refrigerators
Ice maker won't work for kenmore 106.54786802
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
carldc3
  • 82 Answers
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
Posted on Jan 05, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
Kenmore
Can you check if the ice maker fill tube clogged with ice?
If the answer is Yes, it means that water valve is leaking, then you will need to replace water valve.
If not, try manually activate ice maker.
Jun 08, 2013 | Refrigerators
Ice maker is not working. doesn't appear that it's
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Have a good day : )
Sep 03, 2011 | Kenmore Side by Side Refrigerator
Ice maker in side by side Kenmore refrigerator model number 106.55529400 has stopped working.The ejector fingers are not stopping in correct position,from what I have read online this means ice maker...
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
.2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope i can help you with your problem.
Have a nice day : )
Aug 22, 2011 | Kenmore Refrigerators
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
Hope i could answer your problem.
Thanks have a good day : )
Feb 19, 2011 | Kenmore Refrigerators
Kenmore elite ice maker stopped making ice,
Hope thiswould help you
Have a good day : )
Jan 01, 2011 | Kenmore Refrigerators
Kenmore side by side ice maker not working, water does work, checked the back not a frozen line. The problem occurred when the compressor/start device was replaced in the summer. The repairman said that...
Hope it help you.
Have a nice day.
Dec 06, 2010 | Kenmore Refrigerators
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
No 110 volt to icemaker
additional info:
it has an infrared beam, so on both side walls has an eye. Also on the right side there is an on/off switch.
Apparently the eyes work Ok because pilot light blinks when the door is open and is solid when I move the plastic arm that cuts the beam.
Mar 05, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
