Question about 1995-2003 Ford Windstar Premier Floor Mats 763201-06 - Carpet
Went to check brake fluid in master cylinder & notice cap was loose and didn't seal. Is this normal or is the seal missing under cap?
    New Friend:
  • 4 Answers
Should be a black rubber seal its not gona ruin your vehicle or anything but something that you can fix from autozone or o'riellys
Posted on Aug 01, 2013
Brake system failure
I think brake proportional Valve (or Brake pressure regulator) which usually a part of Master cylinder is suspicious.
It regulates pressure to Front and Rear brake line.
If I were you, I try to draw air from Master-cylinder side (not Caliper side).
(Bleed from connector between Master-cylinder and pipe, same way as caliper. someone keep pushing brake then you lose connector then tight. Don't forget to put towel under master cylinder to catch brake fluid)
If air trapped in Proportional valve (pressure regulator), pressure won't relay to rear brake line but only front side.
Front has two separate line from master cylinder (right and left) but rear goes in one line from master cylinder then separate at rear.
Did you noticed both rear brake dragged when it's hot day ?
Because when air get hot, air expand and pushes to caliper and drag but not respond to your pedal.
(calipers don't respond when you push pedal, but it's pushes calipers by itself even you are not pushing pedal, when it's hot because air expand)
Sometimes, seal get old and lose pressure for only one side (front or rear).
if this happened after you did brake job, or you notice your brake was vapor locked (too much brake on hot day then brake fluid boiled), maybe air bleed and whole fluid change may solve.
if you didn't have any unusual activity but it gradually losing pressure to rear, I suspect master cylinder (proportional valve seal).
Sorry I don't have exact e46 master cylinder diagram but basic diagram, hope you can understand what I am talking about.
Picture shows "leak" but this case "Air" in somewhere in pink.
or lose seal on rear piston.
Dec 02, 2015 | Halonet 99-05 BMW E46 3-SERIES 2/4/5DR,...
Nkr 200 1991 brake alarm sounds low brake pressure
are you loosing brake fluid? do you notice any leaks? it could be a bad master cylinder or a bad proportioning valve, master cylinder is more common failure.
Jun 09, 2012 | Cars & Trucks
Losing brake fluid with no leak
It's a sealed system, so it's got to be going somewhere, leaking somewhere (or boiling off from severe braking operations over and over). Since you likely haven't experienced extreme braking, it must be leaking somewhere.
You will have to trace all your brake lines from the master cylinder to each wheel to check for any sign of leaking. Front calipers are easy to spot leaks when they leak. If you have drum brakes on the rear, you may need to pull off the drum to check the wheel brake cylinders. Peel back the rubber boot on each end of the wheel cylinder and look for any fluid leaks there.
Another place to check is at the back of the master cylinder. If a seal is bad there, it has been known to leak fluid inside the car, under the dash. Feel around the carpet under and behind the brake pedal for any wetness. If you find brake fluid there, you will need the master cylinder replaced or rebuilt.
Hope you find the problem. Don't forget to check the ABS system and brake lines, too.
Mar 28, 2012 | 2008 Pontiac Grand Prix
I have a 1998 cavalier. My back wheel on drivers side was locking up so had a wheel cylinder replace and a brake line by just someone, then that didn''t help so I took it to all stars and they did...
its possible that the seals in the wheel cylinder were damaged from the previous problem when it didn`t fix the problem.was the replaced seal a new one or a used one that the someone installed or the seals were defective from the manufacture.also were the brakes shoes cleaned of the brake fluid that was on them from the original cylinder leaking on them as this can cause the brakes to lock up,as well as if the brakes are not adjusted properly can cause this as they will catch and turn with the drum until it can`t rotate any more causing the brakes to lock up.as far as the hardware missing then the person that replaced the wheel cylinder didn`t replace everything that they took off or didn`t know what was suppose to be there as far as parts.
Aug 09, 2011 | 1999 Chevrolet Cavalier
I bleed brakes i get good brake for a day or two then they go out again what can i do
air must be entering the system somewhere, check all wheel cylnders for leaks, and check the master cylnder for leaks( some cars's master cylnders leak at the firewall and fluid runs down inside the car under the carpet)
Jul 12, 2011 | 1992 Buick LeSabre
Why is my break fluid keep running out
do you see any fluid on the ground? if not...master cylinder is bad...vaccum is sucking brake fluid into the booster....is your car running poorly sometimes...if so the vaccum is also sucking it into the engine.....120$ should fix this at any brake shop
Nov 07, 2009 | 2005 Toyota Corolla
My 1998 ford windstar abs brake light is on. In the past I had to add brake fluid and in doing so the light went out. I tried that but it continues to burn. Can it be reset?
thats odd. Adding brake fluid shouldn't have kicked on the ABS light..
Low brake fluid would cause your RED parking brake light to come on not the orange ABS light (unless thats what you mean. if thats the case its normal for that light to come on with low fluid. in this case check the brake lines starting to the master cylinder and the components at the wheels to make sure there is no leaks if you go HERE complained about your situation and also noticed a leak on the bottom of the master cylinder (hazardous in more than 1 way) )
not sure of the component locations under the hood of the windstar but check to see if you were bumping wires on the ABS control module when you were putting brake fluid in. may be a loose connection that jiggles loose when you drive.
otherwise it might need a new ABS control module or maybe moisture in one of the components.
Oct 19, 2009 | 1998 Ford Windstar
Brakes Straight To The Floor...
when you filled the master and bled the brakes did the pedal hold our did it slowly go to the floor if it did there is a leak check the back of the master also check the brake rod under the dash , remove all off the wheels and check for leakage do not drive the vech until you done this saftey issuse good luck kdc744
Jan 19, 2009 | 1998 Ford Taurus
E break light is on and break locked up
try this. loosen the two brake lines at the master cylinder so some fluid can excape, if the brakes are now freed up you have a bad master cylinder. look for a swollen rubber seal on the master cyl.cap also. this indicates some wrong type of fluid has been added causing the problem. good luck.
Jan 15, 2009 | 1997 Ford Expedition
1995-2003 Ford Windstar Premier Floor Mats 763201-06 - Carpet Logo
60 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
baire
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
