Question about Vivitar NP60ACcharger) for Vivitar DVR-390H DVR-410 DVR-525HD DVR-530 DVR-545 DVR-5...
I want to upload a video to my macbook pro for an iMovie, but it says I need a Fire Wire...Is it possible to connect my Vivitar DVR 410 to a FireWire cable?
  • 29 Answers
As a tech, I found FireWire cables to be vastly unreliable, but if you just have to have one, do NOT scrimp. Get one that is heavy duty. The thicker the cable, the better. Avoid flexing the cable near the connectors if at all possible.
Posted on Jul 31, 2013
Macbook pro doesnt recognize the panosonic pv-gs9 when connected with firewire
I take it that your macbook pro has imovie on it. If you open up imovie and plug in your camcorder it should recognise the camcorder and give you access to putting the movie onto your mac. Have a look at http://www.apple.com/support/imovie/ it should help.
Mar 03, 2012 | Panasonic Palmcorder PV-GS9 Mini DV...
How to upload videos on my computer using a Vivitar DVR 880HD
The best way to download videos from your camcorder to your computer involves removing the memory card from the camcorder and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camcorder to the computer, and won't run down your camcorder's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any video cataloging program, such as iMovie and Windows Movie Maker.
Feb 07, 2012 | Video Cameras
I want to transfer video from sony Digital Video Camera Recorder DCR/TRV25E to my Macbook Pro. The camcorder uses Mini DV and I have a USB connection between the camcorder & Mac. Please let me know...
Hi - It's pretty easy. You would use the I.Link (Sony calls it) connector which is actually fire wire. So you would need a fire wire cable (about five dollars or so) between the camera and Mac, load up the built in Imovie software and you'll be ready to go.
Here's a link to a good video tutorial demonstrating the process.
http://video.about.com/desktopvideo/Apple-iMovie-video-capture.htm
Have Fun
Regards, Mikeywaf
Feb 27, 2011 | Sony Handycam DCR-TRV25E Mini DV Digital...
Do i need a sd card to operate my vivitar 410
Yes you do. The Vivitar DVR 410 requires a standard SD memory card (up to 16GB) to record images or video. The 410 is NOT designed to accept SDHC memory cards so make sure you purchase the proper type.
Jan 05, 2011 | Vivitar DVR410BLACK Pocket Video Camcorder
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Uploading video from my Cannon Elura 100 to my MacBook
try using the image capture utility when connected to the computer. canons are notorious for forcing you to use image utilities (picture wizard in windows and image capture in macos). my canon xsi did the same thing.
Jun 01, 2009 | Apple MacBook Mac Notebook
How to connect a macbook pro and a handycam DCR-DVD105.
If your cam has a firewire connection, you could plug it into the macbook and use iMovie to transfer the videos over. You can also get an external DVD drive to put those tiny DVDs into to transfer it over.
Apr 18, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
How to get video and audio from sony dcr pc2e into macbook
you should be able to use firewire and iMovie to get the video over in DV format
Mar 15, 2009 | Sony Handycam DCR-PC2E Camcorder
My Mac does not recognize my Canon HV 30 DV when i connect the FireWire.
I've been around the block with this for days, including a fresh installation of the software on my MacBook Pro. Sigh.
Here's what seemed to work:
1) Reset Vixia HV30 (tiny reset button behind the battery). Did not change any settings on the camera after that.
2) Installed Canon's software that dropped some canon-related files in Library/Quicktime folder.
3) Opened new iMovie 6.0.3 and Final Cut Express HD 3.5.1 projects (a) FCE (using Easy Setup in FCE) to Apple Intermediate Codec 1080i60 (b) iMovie 'HDV 1080i'.
4) Connected 4-pin --> 6-pin firewire cable out of the camera to a bus-powered external drive and from the drive, firewire 800 --> firewire 800 --> MacBook Pro 10.5.8.
This was a last-ditch, Hail Mary effort. It worked, and the camera showed up in the System Profiler firewire window, too, whereas it had not before all of the above. Still does not show up when hooked directly from the camera to the FW 800 input, but at least I can capture now.
Oct 18, 2008 | Canon VIXIA HV30 DV Camcorder
JVC GR-D275U Driver for mac
You would need to use iMovie. Most MacBooks come with this already installed but if you can't find it you might have to buy it from apple's website. All you have to do is open iMovie with the camera connected and on and import the movie into iMovie, then you can edit the way you want it to be. iMovie has some great tutorials as well. Importing and editing can take a while, however.
Nov 08, 2007 | JVC GR-D275 Mini DV Digital Camcorder
Vivitar NP60ACcharger) for Vivitar DVR-390H DVR-410 DVR-525HD DVR-530 DVR-545 DVR-5... Logo
141 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
