I have a samsung txr3079whkxxaa when I turn it on after a few minutes it turns off and I must wait for a few minutes to turn it on again;I woul like someone to help me find this solution thank you for help
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Overheating
Temperature is a common reason why many Rear-projection TVs do not perform well when they get to hot. You may start to see your TV shutting down automatically when it overheats. Here are a couple of things you can do to prevent overheating. First make certain any TV ventilation ports are free and clear of debris and dust. Second make sure the TV has enough room for airflow. Third, the temperature in the room should be around 72 degrees. Due to the high degree of heat generated by a rear-projection TVs, it is not advisable to watch TV on a hot days when you don't run the air condition. This could cause damage to your TV.
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option
If the problem persist you have problem with power supply see the video attached.
Posted on Jul 31, 2013
Slinteriors
  • 8617 Answers
SOURCE: TV turns off after short period off time
What model set do you have?
Posted on Jan 14, 2008
  • 3 Answers
SOURCE: TV screen went black/ red blinking light
Once again I find this is the problem that i have with another brand of rear projection tv. Usually this type of issue is down to needing a new deflection board for your brand and model number tv. hope this puts you in the right direction?
Posted on Mar 16, 2009
romsky79
  • 822 Answers
SOURCE: Snow screen
yes! your right! its a cable connector problem.
Posted on May 24, 2009
SOURCE: Samsung SP50L2HX turns itself off, hot or cold!
http://en.allexperts.com/q/TV-VCR-Stereo-1749/2009/9/SP50L2HX.htm
Posted on Dec 01, 2009
ladywinn
  • 5138 Answers
SOURCE: My Samsung HL-R4667W rear projection tv turns off
Lamp or Lamp Fan For replacement Lamps Call Mats Electronics 1-800-628-1118
for other Parts/Boards Call Encompass Parts Distrubtion 1-800-638-3328
Replace Lamp!
Posted on Mar 02, 2010
Testimonial: "Thanks ... I will try it. :)"
When I go to settings and hit Wi-Fi, my networks do not appear. Have no scanning abilities
Samsung Galaxy S4: WiFi not scanning for networks:
Hello:
Try these troubleshooting tips:
1. If this is happening at home, it could be your network setup is having issues, turn off your router/modem, wait 2 minutes, and then turn the router back on.. wait for the router to connect and then try again..
OR
2. Go to:
Settings > WiFi > (remove your network & then re-add it, don't forget you need your WiFi password in order to log back in)
OR
3. Go to:
Settings > Connections (Network Connections) > More Networks > turn on Airplane Mode > wait a few seconds and then turn off Airplane Mode
OR
4. Go to:
Settings > My Device > Turn Power Saving Mode Off
Feb 13, 2016 | Samsung GALAXY S4
S4 wifi will not scan for networks
Hello:
OR
2. Go to:
OR
3. Go to:
OR
4. Go to:
Feb 13, 2016 | Samsung SGH Cell Phones
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Frozen screen
sounds like the digital main board
Jul 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My six month old Samsung fridge freezer stops freezing. But if I switch it off at the wall and wait a few minutes it works again. But then stops freezing again. So I switch it off at the wall for a few...
There is a possibility that you have a problem relating to the internal refrigeration system. It may contain moisture contamination which freezes in the refrigerant feeding device. Shutting it off allows the moisture to melt and restart the circulation of refrigerant. This problem can only be solved by a certified refrigeration technician.
Making sure the condenser is free of dust and dirt will improve the ability of the system filter/dryer to absorb and hold moisture.
Jun 03, 2008 | Samsung Refrigerators
YP - Z5 MP3 player
have you tried waiting a few minutes after this appears? because if you turn it on for the first time, or you have turned it on after resetting it, it takes a few minuted to load. so if you wait a few minutes the main screen should come up.
Oct 15, 2007 | Samsung YP-Z5 MP3 Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
