Question about Refrigerators
Chefmate mini refrigerator
Fridge not cold, compresser starts for just a sec and then off (really hot) looks like thermestat switch is bad need scimatic
SOURCE: Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Posted on Jun 02, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Posted on Jun 01, 2008
  • 9 Answers
SOURCE: Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Posted on Dec 08, 2008
  • 6 Answers
SOURCE: (1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Posted on May 27, 2009
  • 286 Answers
SOURCE: chefmate mini fridge no more
OK If this is a U-line refrigerator. Is the compressor running? The Fan? If both are running then you will have a sealed system issue. If nothing is running then it goes to the thermostat. Bypass the 2 wires from the thermostat to see if it runs.Yes, then replace the thermostat.
Posted on Jul 22, 2009
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
Hi, freezer took a dump two days ago, fridge was still fine. Then 12 hours later the fridge dumped out too. The compressor is hot and the relay looking thing with part number nsk 85851 clicks on for 20 sec...
most likely the start device is bad,look at the left wall inside the fridge near the cieling,you should see a model number,call your parts store,give them the model number on the machine,there is other letters after the g and tell them you need a start device.unplug the machine,until you get the part so you don't damage the compressor,it's not cooling anyway and thhe freezer feeds cold air to the fridge side,a fan blows cold air from freezer to fridge so next time if the freezer has a problem the fridge side is gonna have a problem too,unclip the metal clip and slide the start device off,read the instructions and it will tell you how to install the new device
Feb 06, 2011 | Maytag PTB2153G Top Freezer Refrigerator
I have a Chefmate BC-87/H mini fridge and I lost my Manual and I need to know if #1 is coolest or #9
jeeze! none of these idots who replied are reading your question!!! I have the same issue not sure which is warmer and which is colder. in my full size fridge, 1 is warmer, and the higher numbers are colder. if you found the solution though- i would really appreciate it if you could let me know! my email is mike41062@gmail.com... i have been searching for the user manual online and cant find it anywhere. cant even find a website for chefmate!!!
Sep 21, 2010 | Refrigerators
I have a Chefmate Mini Fridge - BC-50A that does not work. It appears the heat sink fan and the cold sink fan do not have power to the motor. What do I do? nicole.barnes@parknicollet.com
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Nov 19, 2009 | LG GC-051SS Compact Refrigerator
A workman screwed into a waterline on the wall backing the fridge. The fridge subsequently quit working. We think a fuse or something must have been blown and have unplugged a part from the fridge, numbers...
the P6R8MD/OR0502 is a PTC device .. thats a "Positive Temperature Coeficient Resistor" .. that is, it has a low resistance when cold and a high resistance when hot .. it is used to get the compresser started in the right direction ... it costs about $18 so it would be a good idea to test it before purchasing another .. if you know anyone with an ohm meter then they can test it .. it should read low resistance when at room temperature .. .. if it reads open then its bad .. even without that part i think the compresser will hum for awhile but just wont start .. other things (lights, displays) should work ok even if the part is bad .. check to make sure you dont have a blown circuit breaker in your main power panel .. just plug in a lamp to the same outlet the frig uses to check that .. if the lamp doesnt light then go to your fuse box and look for a circuit breaker out of position .. make sure the power outlet and its wiring were not damaged by the water
if you find that you really do need that part then it is available here
http://www.repairclinic.com/Appliance-Parts?s=t-p6r8md-%3d%3d
Oct 04, 2009 | Haier HSL04WNBSS Compact Refrigerator
Chefmate mini fridge no more
Jul 21, 2009 | U-Line 15R Compact Refrigerator
I need to find the manual to the Chefmate mini fridge BC-87/H
Hi, get me a model # and I can look this up for you and try ans assist you.
Thanks
Vic
May 17, 2009 | Refrigerators
Jan 12, 2009 | U-Line 15R Compact Refrigerator
Nov 03, 2008 | LG GC-051SS Compact Refrigerator
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
