Question about GE AJCQ08ACB Air Conditioner
I have a GE window unit model number aeh12amg1. It has worked perfectly but all of a sudden it quit working. Nothing happens when you push the power button. I have reset the breaker in the plug and there is a green light showing there is power there. When I unplug and then plug it back in there is a beep and all the green lights come on on the key pad. any suggestions.
SOURCE: model 97990 Rev4
First, change your batteries. Next, make sure that after you push both link buttons (try to press them as close to simultaneously as you can) that you click the mouse button. Otherwise it won't actually link.
Posted on Dec 18, 2006
SOURCE: GE Wireless mouse 97990 Rev 4 stopped working
From the Jasco website, some other options to try: Batteries: Tracking can be affected by low or dead batteries. Try replacing the batteries with a fresh set and test the tracking. Although you can use rechargeable batteries, alkaline batteries have been found to have the longest battery life. Interference with other electrical products: Other electrical devices may interfere with the radio signal that the mouse uses to communicate with the receiver. Try placing the receiver in a different location, away from the monitor, zip drives, and other electrical devices. Also, try rotating the receiver so it is on its side (or back). Range of the receiver: GE cordless pointing devices can transmit a signal up to 2 meters (appr 6 ft). Make sure the receiver and mouse are within the 2 meters of each other.
Posted on Jun 01, 2007
CompuGuy44
  • 432 Answers
SOURCE: Broken air conditioner?
Try another wall outlet. You may need an extenion cord.
Posted on Jun 25, 2007
ACTECH
  • 80 Answers
SOURCE: No power from the plug at all
GLAD TO HERE THAT YOU SOLVED YOUR PROBLEM..
Posted on Jul 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
Model JTP15. Why did beeper on timer quit working?
The beeper failed from old age. Sixteen years is a lifetime + in the appliance business.
Mar 02, 2016 | GE Ovens
My power window on passenger side suddenly quit working. Then, months later, both rear windows won't work. Driver's side does still work. Any suggestions why the other 3 gradually stopped working?
hi
it happen with me also actually the problem is the power window get jammed from the inner part..... you if you able to open it just open now clean it well then spray the lube into it and for a long time it work properly..... thankyou
Jun 23, 2015 | Cars & Trucks
How to bypass the timer switch on ge dryer
There are a few things that make most "older" GE/Whirlpool dryers quit working. The thermal hi-limit cutout switch sensor and its thermal fuse strip are located next to each other inside the back cover. The part numbers vary by model, but you can jump them out to verify that one or the other (or both) are not working correctly.
25395755-xipalmoknr3fbjmp51kycajc-3-3.jpg They can be ohmed out just like regular fuses to verify whether they are good or not. The black and white ones will read zero ohms when not blown; the silver ones are a thermostat and will be closed when cold, open above a preset temperature.
Of course, you may have bigger problems. All Thomson devices (GE, Whirlpool, Kenmore, Roper, Frigidaire,...) have a mini-manual included inside the unit. With the dryers, it is located in the same cavity as the timer. There are so many similar models that it is difficult to look up the right wiring diagram or operating sequence, so they put a model-specific print inside the unit for quick reference. The major replaceable components will also be listed by factory part number.
Feb 02, 2015 | GE Dryers
Refrigerator quit working, power to compartment lights OK
If this is an American model refrigerator I will need to know the model number to see what may be happening. Can you post the model number? Thanks Sea Breeze1_10_2013_2_30_52_am.jpg
Jan 10, 2013 | Refrigerators
I have a GE Model WSM2700 WSM2780 Spacemaker Laundry stacked washer/dryer combination which is about 8 years old. It worked perfectly until the dryer no longer would turn on. I opened up the unit and...
i had something similar, did the cleaning and double checked to make sure all the wiring was hooked up and not frayed. i then "jiggled" (technical term) the dryer door button and some sand came out. it has been working ever since.
Apr 14, 2011 | GE WSM2780DWW Unitized Spacemaker Washer...
Just quit suddenly. Power at oulet, nothing lit
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms (dead).
Nov 27, 2009 | Panasonic NN-T964SF Microwave Oven
I have a GE small unit that is 5 to 6 years will not start up
About the only thing can suggest is see if a lamp or other will work in the outlet that you have the AC unit plugged into.
May 07, 2009 | GE AJCQ08ACB Air Conditioner
When I press Start - Runs for 5 seconds and stops.
I tried the "side dish" option with a glass of water in the microwave. The turntable continued to turn - it didn't turn off in 5 seconds- but then smoke started coming out of every vent. I think that killed it. I decided to go buy a new one.
Jan 14, 2009 | General Electric GE Profile CounterTop...
Alpine CDA 7843E head unit
if this unit has a motorized face the ribbon cable is bad and will need to be replaced
Nov 25, 2008 | Alpine CDE-9852 CD Player
GE AJCQ08ACB Air Conditioner Logo
65 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
