Question about Garden
Nikki carb where does the jet that fell out in my hand when I removed the float go
    New Friend:
  • 182 Answers
That's a small needle there should be a little spot for it to slid on the bottom of float goes down in the hole under the float
Posted on Nov 01, 2013
Need assembly diagram for nikki Carb 79778
You will find a lot of pictures and diagrams
nikki Carb 79778 Google Search
Mar 31, 2016 | Garden
Need expert on nikki carbuerator - no fuel to engine but in bowl
get rebuild kit - air is higher pressure then a gravity fed fuel also turning upside down and back only shows that it moves --rebuild and also soak carb base or replace
Sep 11, 2017 | Garden
Little brass piece with the hole in it and the o ring fell out when I took the bowl off my 17.5briggs. I must have put it back in the wrong place when it back together. Does anyone know where it goes?
Is it a Nikki carb? The little brass piece is the main jet and goes in the long tube in the center of the plastic piece that holds the float and float needle. It is inserted from bottom side and seats in the top of the tube.
Jul 24, 2014 | Motorcycles
Fuel not getting to carb
remove carb...remove float and float jet...blow through with compressed air. Check float height and also check float for holes.
Sep 22, 2012 | Honda Motorcycles
Briggs and straton 205412-0187e1 runs on full choke only rebuilt carburetor due to surging now it only runs on full choke
This engine came with 2 different carbs. Walbro and Nikki. The Nikki carb has a very fussy float plate! I fight them often! Usually there is a problem with the odd gasket that lifts the flat plastic plate and causes a very low fuel float level in the carb so the only way it stay running is to have the choke on. The main fuel jet on both carbs is up inside the threaded area of the bowl nut. When the main fuel jet clogs...and it only takes a speck of something you also get the symptom of having to use the choke to keep it running.
http://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CBRG%5Cimages%5C6359%5C0004.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=24
Main fuel jet is item 117 Nikki or Screwed into item 142 Walbro of the of the above link depending on which carb you have.
The plate I am talking about on the Nikki carb is item 135. The fussy gasket is 137A.
THE threaded area is where all the main fuel supply is drawn from the float bowl. All that must be free of obstructions. Until this is clear and orifices / jets are not obstructed; your going to be running on choke....
Thanks for choosing FixYa,
Kelly
Aug 20, 2011 | Briggs & Stratton Power Products 5,550...
How do you clean the jets
Take carbs off the bike drain any fuel that might still be in carbs,remove black top and the spring,carefully remove the rubber diaphragm,the slide and jet needle will come out,turn them upside down,remove float bowl,remove float,remove the little brass jets, the smallest one is the pilot(idle) jet,the larger one is main jet,then there is a needle jet,soak in carb clean if possible,if no clean then small bread tie to clear the holes.(carb kit),do one at a time so not to get parts mixed up.
Feb 18, 2011 | 1992 Yamaha FZR 600
My 5.5hp honda is surging even with the belt off.is this carb. only or are thier orther factors,such as bad gas
Bad gas can cause the engine to surge, but also the carb bowl and jets need cleaning. I usually drain the gas, remove the bowl, wipe inside the bowl , and then use a carb cleaner to spray the float and jet/s. The float may be hanging up. It would be best just remove the gas and clean the bowl area and float/jets. I wouldn't think replacing the carb. is the problem.
Feb 03, 2010 | Air Tools & Compressors
Not getting fuel
pull carb and clean jets
Jan 30, 2010 | 2004 Yamaha YZ 450 F
I have a Snapper yard cruiser with a 15HP Kohler and Nikki Carb. THis Carb has no way to adjust Idle or High Speed fuel mixture. Since this engine repeatedly stalls with any load on it ecold or hot, I...
Correct that there are no adjustments, but try cleaning the carb jets first, as many times a small amount of debris in the fuel can cause a performance problem. A replacement carb will be close to $200, and NO carbs will be adjustable. A gasket kit is available if you need. Contact your local Briggs dealer to procure the part.
Try cleaning the jets first.
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 21, 2009 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
